new fender flares or fiberglass fenders for my zr2
Old 02-21-2012, 06:09 PM
neo71665's Avatar
Lmao about you guys and cutting fenders.
Prerunner (any glass fender) requires you to drill out all the spot welds and pull the steel skin off. Installing fenders are just like flares, you have front and rears. Only using front fenders looks stupid just like only using front flares. Same retarded look as running around with the front jacked up.
Old 02-21-2012, 07:15 PM
Jamaroon's Avatar
except they don't make rear pre-runner fenders for blazers so you'd have to custom make them. which would be a ton of work and most people wouldn't be able to do a good enough job to make it worth while.
we still have the stock rear flares so it's not like there's flares in the front and nothing in the back. most people (unless they know all about ZR2's) don't even notice the difference.
I don't know what your point was supposed to be.
Old 02-22-2012, 02:28 AM
neo71665's Avatar
They make s-10 bedsides all day long. You cut them and they will fit on a blazer with a small amount of work. You can also pull the sides about 3 inches if you want to keep the steel but make it wider. Its been done plenty of times. At least 6 blazers on desert dimes set up as a prerunner. Personally I'm makeing a mold for a 4 inch wide dually style fender for my first gen.
2000Bansheeboy
12-10-2011 01:14 AM
LunchBox
11-27-2007 08:11 PM
Quick Reply: new fender flares or fiberglass fenders for my zr2
