rust hole in rear passenger door into wheel well
i developed a rust spot from my rear passenger door jam into the wheel well...the hole is about 2x3 in the door jam, and about a 1x1'' in the wheel well.
i cleaned it all out which is why the hole is bigger, should i just bondo the hell outta it? or is there a better option
pictures can be provided if needed,
thanks in advance
thanks in advance
Is expanding foam something I can purchase at Walmart? Lol. Yea the foam already in there is soaked. ..shocker...since its hollow inside, should I get the wet foam outta there and buy the bondo self adhesive mesh and go about it like that?
Gonna head out and grab all the remaining supplies including expanding foam. Thank you for the great advice guys. Will hopefully have some before and after pics sooner than later....cant keep up with this damn weather lol
If you REALLY want to go the foam route instead of welding in some new metal.
Search around on the internet, I believe there is some expanding foam that resists water if I have read correctly. Do some searching first.
You would need access to a welder or someone who welds to fix it properly. Depends how llong you plan to keep or how long you think the truck will last you. Foam and bondo 2-3 years, cut out ALL the rust and weld 10+
