Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
Designing a plug in ECU chip emulator.. any interest?
Old 09-24-2009, 11:02 PM
jamez70's Avatar
jamez70 is on a distinguished road
Exclamation Designing a plug in ECU chip emulator.. any interest?
Hey all,
I'm an electrical engineer, and recently I have taken some interest in ECU tuning. I own a 95' blazer myself and I have been tweaking around and seeing what I could do.
Anyway, I am currently designing a plug in emulator for the EPROM socket inside the MEMCAL adapter that would allow you to program the ECU installed. I cannot reveal much more information at this time until the design is complete, but it will enable you to upgrade the software in the ECU without physically removing the chip from the computer.
This would be on any GM car, pre-1996, and would also allow multiple copies of software to be installed which could be switched on the fly in order to try different parameters.
I will probably set the target price around $50-$60 for the completed design, much more reasonable than any other solution of this type.
Does anyone have any interest in something like this? I'm trying to get a feel for how much interest there would be in order to judge whether the efforts of designing and manufacturing this is feasable.
Please let me know.
Regards,
Jim
Old 09-25-2009, 12:58 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
Hi Jim,
im still not sure what you mean. what exactly will this chip do exactly? like will it help the way my 95 S10 runs? i might be interested if i understood what exactly it does or can do. please let me know, thanks so much
Old 09-25-2009, 02:20 PM
jamez70's Avatar
You can change the code in the computer.. You could change spark tables, disable EGR, air/fuel ratios... anything you wanted to do.
Old 09-25-2009, 03:26 PM
rriddle3's Avatar
Including frying your computer and/or engine?
Old 09-27-2009, 02:41 PM
jamez70's Avatar
LOL.. Not likely unless you're a real ****
Old 09-27-2009, 03:05 PM
rriddle3's Avatar
If your program allows users to adjust critical function parameters without any limitations or safeguards, then trust me, there will be folks who screw it up.
Old 09-27-2009, 04:56 PM
not if you follow instructions or stay within the safety parameters.....i think its a great idea...especially if you plan to take a long drive trip. the truck can run with they way you program it so that you have less of a chance of something failing while on the long trip and getting stuck.... im interested in it.....
Old 09-29-2009, 12:19 PM
jamez70's Avatar
I'm still in the design phase, and should have something done in the next few weeks hopefully.
Of course you could screw the engine up, but thats the risk you take when tuning. Tuning via the computer is something you have to do carefully. This device will make the process easier.
I've been tuning my ECU occasionally, and I thought this up because its a pain in the *** to change things. I have to pull out the MEMCAL, put it in the programmer, program it, then put it back in the ECU. This will enable you to program it right in the ECU without having to remove it to pull out the MEMCAL.
RWarrior
06-09-2010 09:37 PM
88blackzcand95blazer
Engine & Internal
14
01-24-2009 07:15 PM
boulonman
03-05-2007 05:10 AM
alphawhisky
01-14-2007 12:16 PM
a_tack
12-24-2006 01:30 PM
Quick Reply: Designing a plug in ECU chip emulator.. any interest?
