Throttle Body mod
#21
Temperature has A LOT to do with things as does accessories being driven. What was it, 90F+ six months ago in FL and now somewhere around 70F? Probably don't have to run the AC much this time of year. Just that means your observations are flawed and now you mention a **** ton of additional work htat has been done to it...
Just to put some more info out there, I saw just under a 0.8 second difference in the 0-60 averages for AC-on vs. AC-off in my old Bravada on a 85F day, absolutely no other variances and allowing a 10 minute idle session between each of the 10 total runs.
Listen, I completely believe that you think your truck got faster and if that makes you happy, good.
#22
Unless you put a stock throttle blade on ran 5 passes from the exact same starting point to the exact same ending point and then immediately swapped to a modified blade on and ran the exact same setup 5 more times and take the average from before and after you are not getting accurate results.
#23
You have already invalidated your 12 second time, there is no question there. No need to further try to push your gains as no one here is buying it. That's why I said that if you're happy, good. No matter what you do from here on out (short of testing it with a stock throttle blade) will change my opinion of your comparison as it involved a truck with compromised injection, ignition, and various other systems for the pre-mod test.
#24
#25
Another item that does nothing , 3 sec. Increase? How far , 5 miles LOL
Jimmybeatergal
03-15-2014 12:34 AM
