Detailing Discuss detailing your Blazer within.
HOW TO: Glass Cleaning 101
Old Aug 6, 2005 | 03:21 PM
Autogeek's Avatar
Autogeek is an unknown quantity at this point
Default HOW TO: Glass Cleaning 101
To view this article on our website, click here.
Glass Cleaning
Cleaning automotive glass is tricky, but well worth doing. Clean, clear glass looks beautiful next to clean, waxed paint. Plus, clear glass will give you optimum visibility when driving. That’s a safety feature you can’t afford to overlook. Just a few extra minutes will add the finishing touch to your vehicle and give you a clear view of the road ahead.
Glass Cleaners
Most glass cleaners contain ammonia, which is a good cleaner but it has some disadvantages. It releases fumes that should not be inhaled in enclosed areas, like the inside of your vehicle. Also, it can dry out plastic, rubber, vinyl, and leather. Overspray is not an option with an ammonia cleaner. Plus, you cannot use ammonia on tinted windows. Chances are, if a glass cleaner does not contain ammonia, it will say “ammonia-free” or “safe for tinted windows”. If the label doesn’t say one way or the other, assume the worst and find another cleaner. Avoid household glass cleaners, which almost all contain ammonia. Some examples of tint-safe cleaners are Stoner Invisible Glass, Mother’s Glass Cleaner, and Meguiar’s NXT Generation Glass Cleaner.
Here’s a tip for tinted windows: Use Plexus to polish and protect the tint. Apply it only to the inside of the glass where tint is visible. It will seal the tint material (Mylar) and keep it clean. Plexus is non-static, non-streaking, and it dries crystal clear.
Some people prefer to use plain water to clean their windows. While this is a very safe method, it may not be effective on stubborn spots, like bug splatter. However, a glass-cleaning microfiber towel, like the Cobra Waffle Weave Microfiber Glass Towel, will provide a gentle scrubbing action to help remove contamination. Dampen this towel lightly and clean the glass. Then buff the glass dry using a dry microfiber towel. High quality microfiber does not produce lint and is extremely absorbent to prevent streaks.
Professional tip: Many detailers use newspaper to dry automotive glass because it will not produce lint. This is not a bad option, but be sure to wash the ink off your hands before touching other areas of the vehicle.
Clean by numbers
1. Detail your vehicle. Glass should be the last thing you do to avoid re-contaminating it during the detailing process.
2. Work out of the sun on dry windows. The sun can cause glass cleaner to evaporate too quickly and leave streaks.
3. Lightly dampen your microfiber towel with your cleaner of choice. Wipe down your windshield, and then immediately buff it with a dry microfiber towel, like the Miracle Towel. This will prevent streaks. Do the same on the outside of the back windshield.
4. When you clean your windows, be sure to roll them down to clean the top edge.
5. Whether you clean all your inside glass first, all the outside glass, or window by window is up to you. The advantage to cleaning one window at a time is that you’ll immediately see any streaks you left on the outside when you get in to clean the inside.
6. You can’t always get it right the first time. It may take a mist of glass cleaner to remove stubborn film and then another cleaning with plain water to remove any streaks created by the film. It all depends on exactly what is on your glass. Don’t be afraid to use more than one cleaner on the same window, if that’s what it takes.
7. When you clean the inside of the back windshield, it may be helpful to use the backside of your hand to hold the towel ag
Old Jan 12, 2006 | 09:29 PM
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
Default RE: Glass Cleaning 101
On my tinted glass, i use Hope's perfect Glass. It's ammonia free, and it does a hell of a job. It's in a short fat black bottle.
Old Oct 22, 2006 | 04:34 AM
03BlazerZR2's Avatar
03BlazerZR2 is an unknown quantity at this point
if u use news papers to clean your windows with glass cleaner of course it will greatly reduce streaking
Old Oct 22, 2006 | 04:42 AM
4lowlife's Avatar
post back from the dead. Just in time for Halloween!!
Old Oct 22, 2006 | 06:11 AM
Chevy Lover's Avatar
excellent post! I hate not being able to see.
Old Nov 12, 2006 | 08:22 PM
Scoody Boo's Avatar
Scoody Boo is an unknown quantity at this point
I owned a Phillips 66 up until this past summer. Newspapers are the best thing or cleaning glass. I used to use glass cleaner from Dollar Tree and it worked just as well as the more expensive stuff.
Old Apr 18, 2007 | 04:37 PM
rabbit0102030's Avatar
rabbit0102030 is an unknown quantity at this point
Default RE: HOW TO: Glass Cleaning 101
This is a very good write up on keeping your Blazer's glass surfaces clean. Give it a look over and get those windows clean!
Old May 25, 2009 | 10:03 PM
Crestwood1001's Avatar
Crestwood1001 is on a distinguished road
When you use newspaper whats the best way to do it? I assume crumpeling it up is not good
Old May 26, 2009 | 06:09 AM
Yooper's Avatar
Yooper is an unknown quantity at this point
Actually I find it best if you crumple it into a loose ball. IMO I think the best way to go is "Stoners Invisible Glass" and a microfiber towel. Make sure you roll your windows down a bit to get the very top of them. I always hate spending all that time on my windows and then drive somewhere, roll down my window and see that annoying 1" strip of filth on the top of my windows.
Old May 26, 2009 | 09:08 AM
nj4x4blaze's Avatar
"Stoners Invisible Glass" and a microfiber towel ftw!
