Nitrous, Super Chargers, & Turbos All charged talk about going FAST.
turbo?
Old Jun 4, 2007 | 11:26 AM
xdieselx3032's Avatar
xdieselx3032 is an unknown quantity at this point
Default turbo?
wats up everyone...i just saved enough money to turbo my 94 jimm and im really intersted to do it. I just wanted a few suggestions if possible. I wanted to no were i can find a turbo kit for a 94 jimmy i also wanted to no if i have to upgrade anything internal in my engine and whats invloved and what i have to do to get it turbo'd and working thanx appricaite it
Old Jun 4, 2007 | 08:22 PM
erauto's Avatar
erauto is an unknown quantity at this point
Default RE: turbo?
if your looking for power, you need some internal modifications, if you want small boost, its ok. check this site, www.campbellautomotive.com check out their turbo systems on s 10 typhoons, putting out 28psi 800hp. yes not cheap, I priced it out, almost 35000.
Old Jun 11, 2007 | 12:08 AM
02 Vortech's Avatar
02 Vortech is an unknown quantity at this point
Default RE: turbo?
LOL @ 35k!!!!!@#!@#$@#%@#
im sorry guys i still dont see the need for internal mods considering i have run 14psi of boost through my COMPLETEY STOCK LONG BLOCK BS 4.3L. The turbo seals went so i just sent the turbo off to get rebuilt (60-1 compressor w/ .82 a/r turbine ) I ran 14psi through it for about 5, 1/4 mile runs and the 2 weeks after that. Then i turned it back down to 11psi. I have run 8 to 11psi daily for the past year with no worries. The truck isnt even tuned properly (it has a very very safe 10psi base tune) Truck runs great. @ 10psi i am dead even with an EVO VIII (that has a turboback i might add ) if your looking for a weekend warrior that runs low low 13's on a 110* track temp day then just add 13psi
the 96+ motors are supposedly the weaker engines and mine has been fine on 10psi. If you do internals just get a nice set of heavy duty JE pistons 8.5:1, total seal rings, Eagle H-beams and get the stock crank cryotreated with 4-bolt mains and ARP hardware everywhere. That shouldnt put you back more then $6k.... Then if you want to get fancy a nice 2114 EFI set-up- $2000. Head work/valvetrain/cam- $2k.
i wouldnt be afraid to run 550-600whp on htis set-up because thats the set-up im going to.
JDB on s10forum is running 420whp on stock bottom end. COMPLETLY STOCK.
i had to build my entire turbokit. Its rearmount and it works great. they dont make turbokits for your year jimmy. Arent 94's TBI? or CFI? or w/e..... i would jsut do an extra injector set-up or FMU for anything under 10psi + a walbro fuel pump. and only run 5 or 6psi intercooled because of the age of the motor.
97VORTEC
Engine & Internal
Apr 22, 2006 09:17 PM
2klt
Mar 3, 2006 01:10 PM
KurtDCobain4ever
Street N Strip
Dec 2, 2005 01:31 AM
smahala1286
Jun 27, 2005 10:47 PM
02 Vortech
Mar 10, 2005 08:41 PM
