Go Back   Blazer Forum - Chevy Blazer Forums > Modifications > Performance & Brainstorming > Nitrous, Super Chargers, & Turbos
  #21
Old 02-14-2008, 05:48 PM
mdehoogh's Avatar
mdehoogh mdehoogh is offline
Super Moderator
1998 Chevrolet Blazer
Send a message via AIM to mdehoogh
Default RE: 98 Jimmy Turbo using Typhoon parts:
http://02vortec.tripod.com/
^^^that's 02 Vortech's build thread in case you havent seen it
Matt - 98 4DR 4WD - photo gallery
  #22
Old 02-14-2008, 11:52 PM
94blueknight 94blueknight is offline
Send a message via AIM to 94blueknight
never really saw the build up but i've seen his blazer b4 either on this forum or a diff one. love how it says rice killer lol
blazerforums.net
  #23
Old 02-15-2008, 03:24 AM
TheBrettster TheBrettster is offline
Super Moderator
Send a message via AIM to TheBrettster
I have most of the parts its just im low on funds to finish it. Its not a cheap project.
2004.5 Silverado SS HD
AAZK 4Lyphe
  #24
Old 02-26-2008, 06:07 PM
UR50SLO UR50SLO is offline
Anyhow.. here's the pic's from today. Love the Marine intake baby!
I Epoxy'd the steel upper to the allum. throttle body.. has not moved since I put it on there 6000mi ago. I painted all the pipes... cleaned up some of the wireing and put a second thin O-ring on the injectors to seal them up. If you use a newer thin injector it should not be a problem.. they just put big holes in these Marine intakes.
Getting closer on the Final tune. HPTuners is the way to go with these guys... No kidding. 10PSI here with No issues. No knock Doing great.
The drivers side pipe is close to the hood insulator so it rubs a bit... but it's a beater right?
1992 Naked Typhoon :1GDCT18Z8N0810881 Help?
Wife's truck 92 Typhoon.... FMIC from 2 GN IC's,AFPR, Autoprom&Tunerpro, Code 59, 65lb/hrs,61dbb turbo,built block. Built 700R waiting to go in. (Going to paint it Sunburst Orange)
06 Broken truck winner Hoping to keep it one year only.
1986 GN Powered Camaro
1998 Jimmy with Stock Typhoon Turbo,DP,Headers! Wife's winter beater!
Who says boys have the toys?
Not at my House!
Life has no meaning with out boost!
98 Turbo 4dr Jimmy,Typhoon turbo/dp/Exhaust mflds, Marine intake 33lb/hr injectors. 10psi daily.
86 Camaro 3.8L Buick powered 3.8L Turbo V6. 10.32@133mph on pump gas on Drag radials.
92 Typhoon
89 Turbo Maxima 13.40@107.89mph.
And more.
  #25
Old 02-26-2008, 07:29 PM
drperry drperry is offline
Send a message via AIM to drperry
More pics + how to are now required
Rear mount turbo isn't really an option for me, since I play in the mud... and I'm pretty sure that it wouldn't be very happy being body panel deep in the mud
  #26
Old 02-27-2008, 12:09 AM
Quote:
ORIGINAL: drperry
agreed!!! how to would be very helpful!!!!!!!!
blazerforums.net
  #27
Old 02-27-2008, 09:43 AM
It's fairly labor intensive.. but the parts shouln't cost that much.
Never Ever buy a FMU to fuel one of these engines. I'm not going to rant on about that but a FMU should never be used to fuel a engine PERIOD. I'd put a piggy back system on before I'd use one of those steaming piles. Ok.. rant finished.
You'll need:
Sy/Ty stock exhaust Manifolds
Stock Sy/Ty style turbo/downpipe
Marine Intake Manifold (e-bay) 400.00 ish.
30lb/hr injectors or larger.
HPTuners. I have a file setup for 10psi
Some 2.5" mandrel bends (steel)
E-bay Intercooler
Moroso 2-part epoxy to affix a bonnet to the Throttle body. Or have a flange welded on ... A guy on another site said that a LS1 throttle body is the same size but has a nice long snout on it that you could attatch a bonnet to with out welding! You'd need to transfer the shaft from the 4.3L to keep the same throttle apendages.
Cut/weld pipes so it's arranged in a flowing fashon.. like mine or not..up to you.
You'll need to plum the oil feed off the drivers side oil pressure feed line (above oil filter housing) You'll need 5feet of -4 AN hose and fittings.
There's a fitting you can put where your oil level sensor is for the oil return.
(Guy's with 3.8L F-bodys do it with no problems) I've not tried it yet. I put mine in the hard way... took off pan.. ect.
Coolant feed to-turbo/from turbo.
Relocate MAF Pre-turbo.
Put IAT sensor into incoming pipe (after turbo/IC)
Tuning.... Tuning... That's what is going to make or break these setups.
If it's not tuned right or skimp on fueling it correctly/timing/settings you'll be looking at a yard orniment with a blown engine. 4.3L don't take detonation well. It wipes the mains right out of them.
3.8L buicks are more forgiving and just blow head gaskets. We've got too much clamping force on our 4.3L head to blow them out.
I've got a entire set of pictures I can send you if you contact my e-mail.
Hope that helps,
Scott~
UR50SLO@aol.com
92 Typhoon
And more.
  #28
Old 02-27-2008, 11:03 AM
Psychropod's Avatar
Psychropod Psychropod is offline
1996 Chevrolet Blazer
My Garage
Send a message via AIM to Psychropod Send a message via Yahoo to Psychropod
Scott,
You should just create an album right here. That way you don't have to worry about answering email requests for pix. Just a thought.
Raphael - here since '07, but still posting at a Junior level...
The Bloody Blazer | GoldiMaC
  #29
Old 02-27-2008, 01:40 PM
Umm... never done that... Guess I'll have to spend some time learning.. I don't mind answering e-mails...everyone has a different question and normaly needs to be answered differently.
I'll look into it.
Thanks, Scott~
92 Typhoon
And more.
  #30
Old 02-27-2008, 05:02 PM
Anybodyknow what the stock fuel injectors flow rate is?
Tags
38, 43, 4dr, 98, blazer, buick, camaro, chevy, jimmy, mkodd, sale, size, stock, turbo, typhoon, v6
