Go Back   Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > Steering, Suspension & Drivetrain
Old 12-12-2007, 05:52 PM
Millertime21 Millertime21 is offline
Default ZR2 rear end???
I was reading that a ZR2 rear end is a nice upgrade for non-zr2'srear ends, because its a 8.5" instead of 7.5" making it stronger. Just wanted to know if its a direct bolt in? Right now I have 3.42 gears so could I have 3.73/4.10 in back and 3.42 of front, or would that not work? And lastly would the front diff. from a ZR2 bolt right in so I could have matching gears and are the fronts of a ZR2 any stronger than in a stock 96 blazer 4-door? Sorry for all the questions, but any help would be great. Thanks
1996 Blazer LT 4x4
2" PA Body lift
1.5" shackles/ 1.5" T-bar's cranked
32" Sport King A/T
Brute Force CAI
2.5" stainless steel magnaflow cat back
Taurus e-fan
Ford 8.8" rear end (4.10)
Wait4me Tune
http://www.cardomain.com/id/Millert
Old 12-12-2007, 05:59 PM
mdehoogh's Avatar
mdehoogh mdehoogh is offline
Super Moderator
1998 Chevrolet Blazer
Send a message via AIM to mdehoogh
Default RE: ZR2 rear end???
you cant really use two different gears in the front and the back... one axle would be spinning faster than the other = transfer case will die
Matt - 98 4DR 4WD - photo gallery
Old 12-12-2007, 07:14 PM
drperry drperry is offline
Send a message via AIM to drperry
The ZR2 axle is also a little wider, if I remember right...
Any 2nd gen Blazer with a 5 speed should have the 8.5" and the iron front diff.
Old 12-12-2007, 07:29 PM
Thanks. Also since I currently have drum brakes on the rear, do I have to do anything to make the disc brakes on a ZR2 rear end work?
1996 Blazer LT 4x4
2" PA Body lift
32" Sport King A/T
Brute Force CAI
Taurus e-fan
Wait4me Tune
Old 12-12-2007, 10:36 PM
Hanr3 Hanr3 is offline
Yes, and good question.
You will need to change the master and the proportioning valve. Drums require less pressure then discs. Take them from teh donor truck.
-President Ronald Reagan
'87 S10-Blazer - SOLD
'00 S10-Blazer 4x4x4 - My
Old 12-12-2007, 11:24 PM
Idriveachevy Idriveachevy is offline
Are you hacking up a Zr2? if so, send me pm i want to tlak to you about some stuff.
1997 4door 4x4
thrush glasspack
31" bfg mud terrains
2 in. shackle lift and TB crank
Soon to come
- 2 inch body lift.
Old 12-12-2007, 11:25 PM
felonyblazer96 felonyblazer96 is offline
Banned
Send a message via AIM to felonyblazer96
i am hacking up a zr2 any info would be appreciated
[/align]
Old 12-13-2007, 02:26 AM
Quote:
ORIGINAL: Hanr3
Thanks, I had to do that on my camaro, butwasn't positive if it was the same for blazers.
1996 Blazer LT 4x4
2" PA Body lift
32" Sport King A/T
Brute Force CAI
Taurus e-fan
Wait4me Tune
Old 12-13-2007, 02:27 AM
Quote:
ORIGINAL: Idriveachevy
Nope, but I'm going to go junkyard shoping in the next week or two and see what I can find.
1996 Blazer LT 4x4
2" PA Body lift
32" Sport King A/T
Brute Force CAI
Taurus e-fan
Wait4me Tune
Old 12-13-2007, 06:26 AM
Well, if you insist on using an axle from a ZR2, then at least your rear wheels will stick out at least as far as the fronts, lol.
The track width of a ZR2 is wider, you might run into some issues with that.
I have the 8.5" diff, and I'm not a ZR2 [8D]
There's a few 4 doors that have it too... Jigg found one awhile back, lol, even had 3.42's in it.
Tags
10, 75, 85, 88, blazer, chevy, codes, difference, end, forum, forums, rear, s10, sale, zr2
