Go Back   Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > General Tech Help
Old 03-12-2006, 01:54 AM
4lowlife 4lowlife is offline
Send a message via AIM to 4lowlife
Default RE: Transmission fluid loss
Blow out all the atf fluid the best you can.
Old 03-12-2006, 02:31 AM
medion42 medion42 is offline
OK I will try to do that . Do you know the fuction of the vacume switch? Thanks Dan
Old 03-12-2006, 02:32 AM
I think activates when you switch out of 2 hi.
Old 03-13-2006, 01:00 PM
Hanr3 Hanr3 is offline
You need to replace the input seal on the t-case, not the output seal on teh tranny. There is a void where the adapter connects the t-case to the tranny, if the output on the tranny is leaking it will fill up that adapter, and that is no big deal, in fact you need some tranny fluid in there to lubricate the governor. However you need to fix the input seal on teh t-case, otherwise the t-case will get overfull of tranny fluid. Most GM t-cases take ATF.
The vacuum switch controls your 4wdr system, specifically your vacuum activator located on the passengers side fender below the battery. There are three hoses, one hose provides vacuum to the system, one hose provides vacuum to the vacuum modulator under the battery, and the 3rd hose is a vent hose.
You MUST clean out all the fluid in the hoses. Not only does the fluid plug up teh vacuum system for the 4wdr, it is also connected to your heat-a/c vacuum controls. If you have too much fluid it will get into the heat-a/c controls and you will replace them to fix the problem.
Fortunately, you may have caught the problem before it affected your heat-a/c system.
-President Ronald Reagan
'87 S10-Blazer - SOLD
'00 S10-Blazer 4x4x4 - My
Old 03-16-2006, 11:18 PM
Thanks fellows I think we our back in business and it all seem to be working at the moment. Dan
Tags
1998, 96, 97, astro, automatic, blazer, change, chevy, drain, fluid, leak, leaks, loss, oil, rear, tranny, transmission
