Old 04-26-2009, 09:24 AM
swartlkk swartlkk is offline
1974 Chevrolet K Blazer
My Garage
Default HOW-TO: 2nd Gen Temp Door Actuator Replacement
Temperature Actuator
REMOVAL PROCEDURE
The air temperature actuator is located on the top right hand side of the heater/vent module.
1. Remove the instrument panel carrier.
2. Disconnect the electrical connector (2).
3. Remove the air temperature actuator retaining screws.
4. Remove the air temperature actuator from the heater/vent module.
INSTALLATION PROCEDURE
1. Install the air temperature actuator to the heater/vent module. Ensure that the actuator is seated on the locating tab. NOTE: Refer to Fastener Notice in Service Precautions.
2. Install the air temperature actuator retaining screws. Tighten Tighten to 1.9 N.m (17 lb ft) .
3. Connect the electrical connector (2).
4. Install the instrument panel carrier.
5. Perform the following procedure in order to initialize the air temperature actuator on vehicles equipped with automatic climate control (C68).
5.1. Turn the ignition switch to the OFF position.
5.2. Remove the RDO BATT fuse for 10 seconds .
5.3. Reinstall the RDO BATT fuse.
5.4. Turn the ignition switch to the ON position.
5.5. Ensure that the air temperature actuator cycles through the hot and cold range.
6. Perform a heater output temperature check. Refer to Heater Output Temperature Check.
For a description of the RPO Code(s) shown in this article/image, refer to the RPO Code List found at Vehicle/Application ID.
Tags
actuator, actuators, air, blazer, called, chevrolet, chevy, control, disconnect, door, electric, heater, panel, temp, temperature
