Old 04-29-2009, 11:26 AM
swartlkk swartlkk is offline
1974 Chevrolet K Blazer
My Garage
Default Tech Article Summary - Check Here first!
This post will be updated whenever a new tech article gets posted to this section and kept as a summary of all articles broken down into categories, not including the stickies.
General Information:
RPO decoder by zero psi <--needs to be updated
Content & Vehicle Theft Deterrent Information by 20Blazer00
Brakes - Low Speed (below 5 MPH) ABS Activation by swartlkk
1st Gen Abs codes and how to retrieve/clear them by Outsydr
Transmission, Transfer Case, & Drivetrain:
Trans Cooler & Shift Kit Install! by 4lowlife
700R4/4L60/4L60E Tranny Removal by Hanr3
4x4 No Worky.... Maybe this will help.... by Hanr3
4wd Hub/Bearing Assembly Replacement by Hanr3
Rear Axle Service by swartlkk
Mini spool install by zero psi
OBD2 Non-Automatic Transfer Case Diagnostics by lastcoupe & swartlkk
4WD Front Half Shaft Removal by swartlkk
NV233 transfer case / encoding motor switch by error_401
Homemade posi-lock cable system by mysons95
Engine & Internal:
How to replace intake manifold gaskets on 4.3 V6 by pilgrim
Fuel pressure regulator on Blazer 4.3L CPI W engine by kerander
Handmade heat shield and intake by TripleBlackBlazer
Fuel Filter Replacement by lennyblazer
2nd Gen Leaking Remote Oil Filter Lines by swartlkk
2nd Gen #3 Sparkplug Removal compilation from a thread on the subject
MAF Sensor Cleaning by garry2000blazer
Heater Core Flush by a_tack
96+ Fuel System Diagnosis by swartlkk
How to remove Throttle Body 2nd Gen 4.3 by cr8390
EDI Engine Timing by swartlkk
96+ Water Pump Removal & Install by ravenhurst
HVAC:
Air Conditioning Part 1 by DCFluX
Air Conditioning Part 2 - Slow Leaks by DCFluX
Air Conditioning Part 3 - Recharging by DCFluX
2nd Gen Temp Door Actuator Replacement by swartlkk
Audio, Video, & Aftermarket Equipment:
The Big 3 by XBlazer01
Get The Ohms Right! by XBlazer01
Amplifier Specs by XBlazer01
Basic Instalation 101 by XBlazer01
Installing AC plugs and power inverter by EuroGoldLS
98-05 S-Series Radio Removal by chevys rule
Steering & Suspension:
Vibrations by Hanr3
T-bar Crank by a_tack
Front 4x4 Shock Replacement by portcqb
Factory Ball Joint Replacement by icculusjr
Wheels & Tires:
What size tires fit the S10-Blazers by Hanr3
Electrical & Lighting:
Key Switch TSB by swartlkk
Fix for cold solders in the Wiper Motor by swartlkk
Oxidized Headlights by TheBrettster
9005 Bulb Mod by swartlkk
Homemade clear corners by Taymacjack
Ignition Switch Replacement - Book Method... by swartlkk
98+ Hazard Switch Replacement by swartlkk
98+ SIR Airbag Disabling & Enabling Procedures by swartlkk
PASSLOCK - Reprogramming Auto Learn by swartlkk
Ignition Switch Replacement by WolfPack
Broken Hazard Switch Repair by Taymacjack
RKE remote keyless entry fob programming info by kerander
How To: Wire RHD Euro Blazer Tails by Unlimitedsp
Charging System Test (book methods) by swartlkk
Body & Frame:
GMT360 Fuel Tank Removal by swartlkk
Hood Hinge Rattle - TSB 01-08-63-001B by swartlkk
GMT370 Fuel Tank Removal by swartlkk
Window Motor Replacement - Book Method by swartlkk
Rear Bumper Transplantation by DCFluX
Old 04-29-2009, 01:57 PM
rriddle3's Avatar
rriddle3 rriddle3 is offline
2002 Chevrolet Blazer
Holy cow, Kyle! Once again, excellent work. Thanks.
2002 Blazer LS (late year 4.3 engine) 4dr 2WD Auto Trans
Hypertech PP III Programmed
Flowmaster 50 Series Delta Flow Muffler, C6 Corvette Exhaust Tip
TYC Elegante carbon fiber tail lights
Old 04-29-2009, 02:53 PM
My Garage
Changed it around a bit.
