Old 11-07-2009, 10:15 AM
poeticviking poeticviking is offline
Default Overheating
95 s-10 4X 4.3, it's overheating. I know i probably have air in the system. which is better DIY or tire and lube shop. Second, whats normal operating temp for this model. The therm was just replaced. but the thing is, the overheating is erratic at best. one minute 245-255 the next back down to 210. THe fan shroud is toast the bottom is missing completley and the top is cracked and broken. The air intake is much smaller than stock. Do i have alot of issues that all add up or are any of them more significant.
Old 11-07-2009, 10:38 AM
rriddle3's Avatar
rriddle3 rriddle3 is offline
2002 Chevrolet Blazer
Replace both parts of the fan shroud (junkyard should work). They are needed to direct airflow to the radiator.
To burp the system lift the front end with the passenger side slightly higher, remove the radiator cap and run the engine to operating temp watching for air bubbles. Refill coolant as necessary, let the engine cool and repeat the cycle.
The thermostat should be a 195 degree model and the normal operating temp should read just a tick under 210 on the gauge.
2002 Blazer LS (late year 4.3 engine) 4dr 2WD Auto Trans
Hypertech PP III Programmed
Flowmaster 50 Series Delta Flow Muffler, C6 Corvette Exhaust Tip
TYC Elegante carbon fiber tail lights
Old 11-11-2009, 11:40 AM
Default Fan removal?
Will I need to remove the rad fan to instal the fan shroud.
Old 11-11-2009, 12:02 PM
rriddle3's Avatar
Here is a reply Kyle made to another thread concerning that question:
Quote:
Originally Posted by swartlkk View Post
...I had to replace the lower shroud after I hit a dog with my old 2000 Bravada. I just pulled the fan/clutch assembly out and installed it all from the top. It was fairly easy. The bottom shroud has tabs that fit into slots in the radiator tray on the core support. Once you have that installed, reinstall the fan and then the upper shroud.
The 'Search' function is your friend.
Old 11-11-2009, 03:57 PM
Smile thank
I figured as much from looking at it. just wanted to make sure. God if you could see this thing. It was like someone just nailed it with a baseball back a couple of times.
Tags
43, blazer, cap, chevy, erratic, k5, overheating, radiator, remove, s10, v6
