Go Back   Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > General Tech Help > 1st Gen S-series (1983-1994) Tech
Old 12-03-2006, 01:42 PM
FImports FImports is offline
Default idle arm and pittman arm
is it a big job to replace the two items listed above.how to
92 S-10 blazer 4.3
Old 12-03-2006, 02:14 PM
mellon101 mellon101 is offline
Default RE: idle arm and pittman arm
check this out for the idler arm:
http://www.s10forum.com/forum/showthread.php?t=247917
1996 Blazer 4 door 4x4
Old 12-08-2006, 12:16 PM
HOW ABOUT THE PITTMAN ARM
92 S-10 blazer 4.3
Old 12-08-2006, 01:26 PM
frankjc frankjc is offline
Idler arm is easy. Pitman arm I have heard you have to move the steering box. I have also heard that there is a way to get it out without touching the steering box. I'l like to know about the pitman arm also.
1999 Chevy Blazer 4.3
1987 Chevy Monte Carlo LS 4.3
1995 Lincoln Mark VIII 4.6 DOHC
Old 12-08-2006, 02:19 PM
lunatic_magnet lunatic_magnet is offline
Send a message via AIM to lunatic_magnet Send a message via Yahoo to lunatic_magnet
the pitman arm can be pulled off the steering box with a pitman arm puller (larger ball joint puller). you should be able to do it without removing the steering box but the sway bar and/or splash guard may be in the way and have to be pulled down/off.
ive also had mechanics tell me that instead of using the puller to remove the pitman arm, they actually find it easier to cut it off the steering box by cutting through it vertically (parallell to the shaft it attaches to), then prying it open a bit to get it to fall off the splined steering box shaft.
Old 12-09-2006, 12:13 PM
rooster rooster is offline
Send a message via AIM to rooster
yea but ur talking about possibly damaging the grooves on the sterring gear, not a good idea! puller all the way and it does help to at least loosen the bolts for the box , they can be accessed through the drvers wheel well/ or around that wheel, i cant remmeber. but eitherway both are relativly easy and make sure u scribe a mark where the olds arms lined up with the gear/frame and then try and transfer the mark to the new arms (in thje same place of course). this way u might not need an alignment and ur steering wheel will still be straight.
1992 s10 4.3 262 tbi 4x4x2 700R4
1999 s10 2.2 134 L4 vortec 2wd pickup manual
Refuse to lose, Born to booze
Old 12-09-2006, 02:20 PM
hillbillyinOhio hillbillyinOhio is offline
Send a message via AIM to hillbillyinOhio Send a message via Yahoo to hillbillyinOhio
Get a haynes manual. thread locked.
MECP Master Installer
2007 Chevy Silverado Ext cab
system to be determined
155.6 Best on the TermLab
Tags
1994, 1996, 1999, 99, arm, blazer, chevy, idler, pickup, pitman, pittman, puller, remove, removing, replace
