Blazer cranks but wont fire
Old Feb 26, 2007 | 04:34 PM
scottyk's Avatar
scottyk is an unknown quantity at this point
Default Blazer cranks but wont fire
well Im just about done monkeying around with this thing, but I figured I say thanks for your guys direction in my problem..
Im just getting it towed to a mechanic for diagnosis.
I figured I just throw out and ask if there is a simple Tester or diagnostic tool I can buy to find the problem?
...Thats all I have patience for..Thanks again
Old Feb 26, 2007 | 05:00 PM
s15kid's Avatar
s15kid is an unknown quantity at this point
Default RE: Blazer cranks but wont fire
Do you know if you are getting fuel? Could be a fuel filter. If your getting fuel, check your distributor cap and rotor. If they have any corrosion on them replace them and try to fire it up.
Old Feb 26, 2007 | 05:16 PM
scottyk's Avatar
Yes I replaced Rotor, Cap,Plugs and wires.
Fuses are good and battery ground is tight.
Fluids are topped including gas..
fuel pump fires up when the key turns.
But as how to go about checking to see if I am getting fuel or pressure, my knowledge is slim.
Is this a difficult task?
Old Feb 27, 2007 | 07:36 PM
scottyk's Avatar
My buddy told me to look for a valve similar to a tire pressure valve.
He said have someone crank the key while pushing in the little pin on the (fuel pressure valve?)
Then it should squirt gas out through there and that means I am getting fuel.
Unfortunately I cant locate it on my 93 blazer.
Anybody no the location of this?
Old Feb 27, 2007 | 11:10 PM
Kordog's Avatar
Looking at the engine, it is on the right side, behind the intake, just to the right of the dist. It is tucked back there pretty good but it is there. Korey.
Old Feb 28, 2007 | 09:46 AM
*LOCKED upon author request*
I'm trying to consolidate these threads. Here is the originating thread:
radiator replacement and blazer wont start related??
bsbob
Jul 22, 2011 12:48 PM
nyjeepman
34
Mar 15, 2009 07:40 PM
Blazin_Jason
Aug 14, 2007 10:40 PM
Lilcheef
Mar 16, 2007 11:18 AM
