blazer burnout
blazer burnout
hey peeps check out my burn out hope you like it .
http://myspacetv.com/index.cfm?fusea...deoid=28759969
RE: blazer burnout
ONE WHEEL PEEL, HOORAY!
RE: blazer burnout
i didnt say "awsome burnout " that was right after i droped it
RE: blazer burnout
whoa looks like you gotta even it out and burn the other tire!
RE: blazer burnout
the other side wount ever atemt to move all i need is an lsd
RE: blazer burnout
Nothing like a one wheel squeal.
RE: blazer burnout
psh brake stands r weak i do the real burnouts in my blazer. i pulled a pretty nice one showin off to some friends last week. nice cloud of smoke in the mirrors
RE: blazer burnout
This might seem like a dumb question..........but how do you burn out? how do you lock up the front tires?
RE: blazer burnout
The simple answer is brakes.
The complicated answer is you need to hold down the brakes and slowly let up until the rear wheels start to spin. The proportioning valve puts most of the braking power up front anyway. Once you get used to doing them you kinda have a feel for how much brake is needed and you can do it right away like in the vid above.
Or you can cheat and put a little bleach/other slippery fluid under your rear wheels.
RE: blazer burnout
WE ALL NEED G80s!! someone should set up a group buy.
