Need help with transfer case PLEASE!
Old 02-07-2013, 02:57 PM
Tom Shorkey's Avatar
Tom Shorkey is on a distinguished road
Question Need help with transfer case PLEASE!
Front axle is locking up with the front driveshaft on my 4 wheel '98 Blazer off. I thought I would be able to drive it in rear wheel only until I get new transfer case, but front wheels are still locked up! Any suggestions? (The flange from the drive axle to the transfer case is broken...it looks like the bushings are broken where it meets the driveshaft. Could this be why the wheels are locked? Does the flange come out?)
Thanks in advance, Tom.
Old 02-07-2013, 04:27 PM
rockp2's Avatar
Remove the battery, remove the battery tray, disconnect the metal spring looking clip from the vacuum canister. This should disengage the front axle locking cable. You might need to pull the cable out of the canister and tie it off until you're ready to put everything back together.
Old 02-07-2013, 04:56 PM
Thanks for the info. Will try it tomorrow and let you know how it goes!
Flyfishen
06-18-2019 11:22 AM
bensaintonge
12-03-2013 08:14 AM
Woody13
03-01-2011 09:13 AM
panophobiac2006
04-12-2009 01:56 PM
95_4door
03-21-2008 07:22 PM
Quick Reply: Need help with transfer case PLEASE!
