Idler arm
Old 02-06-2013, 01:16 AM
Chris Jessee's Avatar
Chris Jessee is on a distinguished road
Default Idler arm
I have a 96 GMC Jimmy 4 door 4x4. I am trying to replace the idler arm. Does anyone know any tricks for getting it out of the center link. I have tried a pickle fork and a 4lb hammer.
Old 02-06-2013, 07:04 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
keep on forking it with a big hammer. it'll eventually let go. They get really in there sometimes.
Old 02-06-2013, 11:11 AM
Diaita's Avatar
Diaita will become famous soon enough
Make sure you leave the arm bolted to the frame while you are trying to break it loose from the center link. A pry bar pulling the two apart and a sharp blow to the side of the center link beside the taper should be all it takes.
Old 02-06-2013, 11:34 AM
newguy's Avatar
I always leave the nut on flush with the end of the bolt and give it a good whack
Old 02-07-2013, 07:15 AM
I have found a tie rod separator that I am going to try. I will let you know how it works.
greatwhite
11-28-2010 11:54 PM
88s10Blazer
12-24-2009 08:43 PM
GMdesigner
08-23-2007 04:57 PM
kornphlake
12-18-2006 02:18 AM
RedOctober
10-11-2006 09:00 PM
Quick Reply: Idler arm
