2000 Jimmy front axle seal leak
Old 07-25-2008, 12:00 AM
toaks's Avatar
toaks is an unknown quantity at this point
Default 2000 Jimmy front axle seal leak
I have a slight leak at the lip seal of the front differential to the front driveshaft. I just purchased the truck so I dont know how much it really leaks. I wiped it clean the other day and there is just a very small "drip" at the seal location when I checked it again today. The "leak" never even amounts to a drip on the driveway so Im thinking that the leak is most likely nothing major. The 4x4 works beautifully with no noises or other problems. I have used the 4x4 on sand and it works great, I was very impressed with the capability. Is this a pretty common problem? Could the seal suddenly blow out, causing major damage to the front diff? Any info from somebody who has had a similar problem would be greatly appreciated.
Thanks in advance,
Tom
Old 07-25-2008, 12:03 AM
toaks's Avatar
Default RE: 2000 Jimmy front axle seal leak
Also, just thought I should mention:
2000 Jimmy, 107k, autotrack 4wd (with the auto 4wd, 2hi, 4hi, 4lo options).
How can I check the fluid level? Any diagrams/instructions would be really helpful.
I will try to get a good pic of the seal and leak and post tomorrow.
thanks
bensaintonge
11-09-2013 03:48 PM
iamchevyman5
32
12-20-2012 11:20 AM
Chic_Bowdrie
07-05-2012 05:47 PM
ComputerNerdBD
08-09-2011 08:04 AM
dougg01
04-28-2010 08:38 AM
Quick Reply: 2000 Jimmy front axle seal leak
