4wd light flashes but no 4wd - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 11-17-2009, 07:37 PM
LJ809 is on a distinguished road
Default 4wd light flashes but no 4wd
I have a 2000 s10 blazer with 4wd auto 2hi 4hi 4lo light is flashing but 4wd won't engage mechanic said there was no communication at the tcm and it could be the body control module or the transfer case module . I replaced the tcm (used part) no change. Any ideas before i replace the bcm any.
Need 4wd before the winter thanks
Old 11-17-2009, 09:34 PM
BCM has nothing to do with the 4wd system.
Clean all of the connections at the TCCM, switch, and encoder motor on the side of the transfer case.
Then test the switch for proper resistance values. Search for "nv236+resistance" and you should turn up the proper information. You can also search for "nv236" and get even more threads. Remove the quotes in both cases when you type that into the search tool.
Old 11-17-2009, 11:34 PM
Thanks for the info i'll check it out and let you know how it went
Old 11-18-2009, 06:57 PM
Monkeyman is on a distinguished road
Try stopping and putting the truck in Neutral before you hit the 4wd button and/or backing up (slowly) a bit after you press the 4wd button (especially 4lo).
Old 11-25-2009, 09:43 AM
Tried putting it in neutral that didn't work but 4lo worked when i put it in reverse but i couldn't switch it back to 2 hi drove around tried reverse again still wouldn't switch. Finally tried neutral again and it switched to 2hi the tccm is clicking only when 4wd actual switches any ideas?
Closed Thread
Thread Thread Starter Forum Replies Last Post
Check engine light flashes at highway speeds. Have run out of ideas. Help please. tazz9690 2nd Gen S-series (1995-2005) Tech 85 09-21-2012 09:51 PM
4x4 flashes but seems to work a2dadamm 2nd Gen S-series (1995-2005) Tech 0 01-31-2012 11:15 AM
99 S-10 blazer, service light flashes at 30mph kristconrath Engine & Transmission 2 08-24-2010 01:38 AM
4WD HI light only flashes, but 4WD works. scrawford 2nd Gen S-series (1995-2005) Tech 1 12-29-2009 06:51 AM
check engine light flashes teddybeer21 2nd Gen S-series (1995-2005) Tech 3 01-07-2009 09:25 PM
Tags
2000, 4wd, blazer, chevy, drive, flases, flashes, flashing, forum, light, lights, switch, times, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
