4WD problem with my 1999 Blazer - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 08-22-2009, 06:23 PM
snaumo is on a distinguished road
Default 4WD problem with my 1999 Blazer
I have a 1999 Chevy Blazer that is equipped with 4 button push-button 4WD. In the 2 years that I have owned it I have never had a single problem with the 4WD. One day I started the car up and was driving along when the service 4WD light came on, all of the 4WD push-button lights illuminated, and I heard a clicking on the passenger side that sounded like aa turn signal. So I pulled into a parking lot and and tried shifting into 4HI and it would not shift. So after i got home I tried taking the battery out for 15 min. to reset everything. I started the car up again and I could shift it into 4HI and 4LO. But it got stuck in 4LO and would not shift out even when stopped in nuetral. I would press the 2HI button and it would blink for a while and not shift. So I took the battery out for 15 min. again. When I started it again I was able to shift back into 2HI. I am afraid to try the 4WD again for fear of getting it stuck. Can anyone help me?
Please Help!
Old 08-22-2009, 08:26 PM
Start by removing the passenger side kick panel and seeing if there is corrosion on the electrical connection on top of the TCCM. If that checks out ok, then search for "NV236" or "NP236" and you should find a number of threads concerning the diagnostic checks that can be performed on the transfer case control system your vehicle is equipped with.
Old 08-22-2009, 08:39 PM
Quote:
The kick panel under the glove box right? Would the transfer case control module be a little black box with a blue connector?
Old 08-23-2009, 07:28 PM
bump/
Closed Thread
Thread Thread Starter Forum Replies Last Post
Is the 1999 S10 muffler the same as the 1999 Blazer LT muffler? kamilkowalski General Chat 3 04-30-2015 09:36 PM
1999 4WD problem debwri Engine & Transmission 3 11-03-2011 11:47 AM
1999 Blazer "Service 4WD" msg - intermittent 4WD engagement. Possible solution. Geir 2nd Gen S-series (1995-2005) Tech 0 10-09-2011 09:51 PM
1999 Blazer 4WD problem snaumo 2nd Gen S-series (1995-2005) Tech 3 08-22-2009 07:43 PM
1999 Blazer 4.3V6 4WD won't start, electrical problem Dahlin Engine & Transmission 2 02-19-2009 02:53 AM
Tags
1999, 4lo, 4wd, 99, blazer, chevy, electrical, kicks, location, module, problems, service, shift, stuck, system, troubleshoot, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
