00 shock and leaf question
Old 11-17-2008, 10:09 PM
zr2juan's Avatar
zr2juan is an unknown quantity at this point
Default 00 shock and leaf question
Got a 00 zr2 blazer how do i know if the shock or leafs are bad? i ask because i pulled up next to another blazer and they were higher in the front and back with same tires, mine newer. Then i started to check and my left side has more gap between top of tire and fender flare. any help appreciated oh truck has 120k and is driven daily 150miles
Old 11-18-2008, 01:46 PM
AJBert's Avatar
AJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the rough
Default RE: 00 shock and leaf question
What you have is known as having a saggy ***. Very, very common. The leafs that were put on at the factory are there more for comfort than for usefullness offroad. The two most common fixes are shackles or AAL's. Either will get your rear end up where it belongs.
As far as to find out if the shocks or leafs are bad:
Bounce the back end of your blazer. If it keeps bouncing, replace the shocks.
Look at your bumpstops. If they look like they have been pummled over and over, replace your leafs.
You should be able to feel both if they are bad through the seat of your pants when driving over some bumps.
Old 11-18-2008, 01:48 PM
You can also have a look at the springs themselves. You are looking for cracked leaves where they run over top of the axle. A friend of mine has a 2000 Bravada that has a cracked leaf in both rear spring packs. I keep on telling him he needs to get them replaced!
Old 11-18-2008, 11:44 PM
zr2juan's Avatar
thanks for help
cpolson.cp
08-23-2015 05:47 PM
gitch93
10-24-2012 12:07 PM
showteam2008
09-23-2012 10:24 PM
LucasMI
01-02-2012 02:15 PM
musclemasterflex
Suspension Tech
08-26-2011 09:10 AM
Quick Reply: 00 shock and leaf question
