95 blazer 4wd indicator lights - Simple Question - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 11-19-2008, 05:13 PM
BIGGER_HAMMER is an unknown quantity at this point
Default 95 blazer 4wd indicator lights - Simple Question
Hey All,
I have a New (well new to me) 1995 blazer.
I read the owners manual but it did not give a clear answer, so time to Go to the Pros!
I have a simple question about the four wheel drive system indicator lights.
I have the three button system (2 Hi, 4 High & 4 Low) When I push the "4 Hi" or "4 Low" switches, the pressed switch lights up and stay lit.
However when I go back to "2 Hi" there is no light. Should this switch be light or stay lit under normal driving?
If it is not lighting, is this an item that I can repair?
Thanks
BIGGER_HAMMER
Old 11-19-2008, 08:26 PM
WolfPack's Avatar
WolfPack is a jewel in the roughWolfPack is a jewel in the roughWolfPack is a jewel in the rough
Default RE: 95 blazer 4wd indicator lights - Simple Question
Yep it should stay lit. If the other two work, I'd say you just have a burnt out bulb/LED..cant recall which is in the 4wd switch.
Old 11-21-2008, 03:00 PM
trouty31 is an unknown quantity at this point
I have the same thing going on with my "new to me" '95.
I figured that the 2 Hiwas supposed to be lit because at night, those buttons are too hard to see if they are all dark.
Is this a common bulb that can be picked up anywhere?
Closed Thread
Thread Thread Starter Forum Replies Last Post
2WD/4WD indicator lights off Marcin Engine & Transmission 0 10-27-2013 09:02 AM
97 Blazer Turn Signal Indicator lights stay on SL5417 2nd Gen S-series (1995-2005) Tech 3 01-23-2013 01:43 PM
Need simple help simple question adaptechsolution Engine & Transmission 18 04-07-2012 01:03 PM
simple question mudsliner General Tech Help 10 11-26-2006 01:56 AM
Simple Oil Viscosity Question 4WDBlaze Engine & Internal 3 10-20-2005 01:05 PM
Tags
1995, 4wd, 4x4, 95, blazer, bulb, chevy, drive, indication, indicator, light, lights, lit, panel, switch, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
