99 Jimmy 4x4 humming noise - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 12-24-2009, 08:15 AM
MissCee72 is on a distinguished road
Default 99 Jimmy 4x4 humming noise
99 Jimmy SLS 4x4 4.3 v6 vortec - 119k
I totally love this truck, why I don't know. All it does is drain my wallet.
I've replaced so much on this truck, it's pretty brand new in repairville. New: oil cooler lines, rear end, u joints, 4 axles, upper/lower ball joints, injectors, water pump, left & right front hubs, brakes, rotors, 4wd vacuum sensor, heater core, and the normal preventative maintenance as recommended.
Recently, it has been humming very loud from the front end. There is no change in the RPM's, no change in the way it feels on the road. The only change is the fact it hums, and seems to go: "woop woop" when I turn the corners from the engine. So, a week ago I the tension pulley replaced as it was shot. And I replaced the idler pulley and belt for good measure. The sound is still there. The crank pulley seems to be out of round, and kinda matches the "woop woop" sound I am hearing. Replacing these 3 things seemed to take the sound down some.
Another thing, my dash panel for the 4x4 went out a couple of months ago, and before it went out, my "service 4wd" light was coming on & going off intermittently. When I took it in to pull codes off, the light would go off when I turned off the truck, and would only come back on over 40 mph. Eventually the light just stopped coming on, and dash panel went out.
But, my main concern is this noise. Anyone have any ideas?
Closed Thread
Thread Thread Starter Forum Replies Last Post
humming noise while in 2WD 02Chevy Engine & Transmission 1 11-07-2007 06:39 PM
Humming noise at high speeds streblo 2nd Gen S-series (1995-2005) Tech 7 11-05-2007 06:31 PM
humming noise from front end tommychet 2nd Gen S-series (1995-2005) Tech 3 12-24-2006 03:31 PM
Humming noise!!help please!! blazerium 2nd Gen S-series (1995-2005) Tech 11 12-14-2006 05:31 PM
weird humming noise blazinloud Engine & Internal 3 09-10-2006 07:01 PM
Tags
4x4, 99, audio, blazer, change, chevy, end, front, hum, humming, joints, loud, noise, sound, universal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
