adjusting setscrew on steering box... - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 02-28-2008, 08:08 PM
stevelknievel is an unknown quantity at this point
Default adjusting setscrew on steering box...
my steering isa little loose and i know theres a setscrew on the steering box (which im assuming is what is wrong because i just threw new tie rods and such under it)
can anyone tell me where it is?
Old 02-28-2008, 09:44 PM
Default RE: adjusting setscrew on steering box...
Steering Gear
Just be careful. It is easy to over adjust and possibly mess up the steering gear.
Old 02-29-2008, 09:16 AM
George is an unknown quantity at this point
I would hesitate to adjust it,as previously said.
If it has not been fooled with before,or come loose,they usually don't require adjustment.
To do it right, it has to be removed and the oil drained completly,turned todead center, then the worm shaftpreload checkedwith an inch pound torque wrench and adjusted to specks.
It is not a trial and error adjustment.
they will have play at both left and right turn positionsby design, but not at straight ahead position.
If it has a lot of play straight ahead, it needs to be repaired/adj./rebuilt as something is amiss.
Old 02-29-2008, 11:26 AM
jphayes921 is an unknown quantity at this point
my steering was alittle loose, just tightened it up a little drove it. and readjusted. havnt had a problem took five minutes of my time to do. the only issue was getting used to the tighter steering after having a lot of play.
Old 03-02-2008, 02:11 PM
thanks guys
Old 03-17-2008, 09:27 AM
KaptainKen is an unknown quantity at this point
Hi Guys;
I have the same problem at poster stevelknievel... loose steering.
I tried tightening the set screw in the steering box (as suggested) on my (2 wheel drive) '89 Blazer but, alas, no improvement. I fact I just drove it around the block and now it won't "self center" after a turn ... I dont know if "self center" is the right term: the tendency for a car to straighten out if you let go of the steering wheel after a turn is called .... what? Anyway, I don't have it now.
I'll loosten up the set screw a bit right away.
In any case, this set screw adjustment "fix" didn't do the trick ... I still have about 3 or 4 inches of play (as measured on the rim of the steering wheel) before the steering engages and turns the front wheels.
Can anyone suggest what my next step should be? Thanks in advance.
Best regards,
Ken
Old 03-17-2008, 10:30 AM
Adjusting the set screw on the steering box should be a LAST resort attempt to fix a loose steering situation, just prior to replacing the steering gear itself.
Other sources of play would be in the pitman arm to gear box spline, pitman arm to linkage joint, worn out idler arm, and/or either of the inner and outer tie rod ends being worn.
Old 03-17-2008, 12:37 PM
Blazin_Jason's Avatar
I too had some play and adjusted the gear box, and it helped quite a bit. I replaced the tie rods, and my idler and pitman weren't too bad. I would also suspect the steering shaft, as the rag joint can wear out.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Heavy steering with new steering box ctyler Steering, Suspension & Drivetrain 6 01-04-2013 02:37 PM
Steering loose. Adjusted gear box and checked linkages. Box need replacing? AKCoastie 2nd Gen S-series (1995-2005) Tech 13 11-01-2010 04:41 AM
Steering Gear Box Replace/Steering Wheel Misaligned caseroj Steering, Suspension & Drivetrain 7 10-20-2010 09:10 AM
Adjusting Timing 88s10Blazer General Tech Help 7 09-01-2006 06:55 PM
Adjusting lower hood hinge brackets on 2001 Blazer Scream And Fly General Tech Help 2 08-26-2006 01:25 AM
Tags
89, 92, 97, 97jimmy, 99, adjusment, adjust, blazer, box, chevy, gear, gearbox, jimmy, loose, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
