rear end size
Old 01-31-2009, 05:15 PM
navygunner61's Avatar
navygunner61 is an unknown quantity at this point
Default rear end size
i have a 97 blazer 4dr. 4x4....can someone tell me what size rear end i have a what would be a safe amount of RWHP this rear end could handle.....looking to replace the 4.3 with a built 350 sm. block
Old 01-31-2009, 08:06 PM
TripleBlackBlazer's Avatar
Default RE: rear end size
You most likely have the 7.5" or 7 5/8" rear. 28 splines. Check your glovebox for RPO G80 which is the limited slip differential. Also look for a GU(#) code, most common being GU6 that is 3.42 gears. You will have to ask some of the V8 swap guys if they did anything special to beef up their rear diffs.
Old 02-01-2009, 09:12 AM
jayve bass's Avatar
jayve bass is an unknown quantity at this point
Question: (not to steal the thread...but) If your glove box code doesn't list G80...Think mine says G06, can you swap out internals from a limited slip. Are the housings the same size? Maybe I'm looking at the wrong sticker...?
Old 02-01-2009, 10:33 AM
G80 is the carrier, (internals as you put it) not the housing so yes you can swap out a non G80 with a G80 but you will have to get the pinion to match the carrier which requires you to set up the entire rear end with backlash and all that nonsense. It is easier to find an entire rear axle with the G80 already installed and swap out rears unless you have the expertise to set up the rear yourself or the finances to pay someone to do it. However, I do not know of any 3.42`s (which is the GU6 you mentioned) that were also limited slips so unless you have 2wd you are also looking at replacing the front differential to match the gearing of the rear. 3.73`s were the most common limited slips in our trucks.
You could also get a drop in locker from Summit but again it is a matter of $$$.
Old 02-02-2009, 05:39 PM
jayve bass's Avatar
Thanks trippleblack. Would this work for a limited slip with the 3.42 gears?
http://store.summitracing.com/partde...4902613+400018
doktornasty
11-03-2013 03:12 AM
BackwoodsBogger14
Headers, Intake, & Exhaust
10-08-2013 12:20 AM
brino1
02-25-2011 08:05 PM
mx_579
Tires and Wheels
09-18-2009 11:36 AM
SanfordBlazer
03-12-2009 08:20 PM
Quick Reply: rear end size
