Bravada driveline vibration 40-60mph and 70+
Old 06-14-2013, 04:05 PM
dsmproject's Avatar
dsmproject is on a distinguished road
Default Bravada driveline vibration 40-60mph and 70+
Ok, I will try my best to explain my issue and what I have done to resolve it, this may get long (I will put a TLDR below)
I have a 98 Olds Bravada that I have owned for 3ish years. Ever since I have had it, it has had a vibration at highway speeds. Nothing I have done has changed the vibrations, for better or worse. I will list all of my repairs below, not all are directly related to fixing the vibration.
Tires re balanced
Transfer case fluid change - put the correct GM fluid in it, not sure how long it had the incorrect stuff
Lower ball joints - passenger and driver
Swapped wheels and tires with friend (did not change)
New brakes all 4 corners - rotors and pads
New U joints (slightly bent front ears so front u joint was tight - this has since been replaced as you will see below)
New tires
New drivers upper control arm - bushings gone
Front drive shaft removal (no change)
Passenger side wheel bearing
Replaced drive shaft with one from junk yard - installed new u joints
I tried to list these in the order they were done to the best of my memory. The most recent was the driveshaft. As seen above, I slightly tweaked the original one and that prematurely killed the front u joint. This was replaced this morning with brand new u joints and still no change.
Now to describe the vibration - its the entire vehicle, but not violent. Just enough to vibrate the mirrors and rattle something in the dash . This does not matter how fast the engine is spinning. I have tried manually changing gears while this is happening and nothing changes. I also put the truck in N and turned the engine off, no change. I had a buddy ride with me, he sat in the front seat and moved to the back and said he noticed it more in the front of the vehicle than the back.
I am running out of ideas. The ONLY thing that is even on my radar is the transfer case. Now the reason I say this, is my in-laws have a same year Bravada which I compared to mine. I know the transfer case should have some rotational "slop" however mine has 2 times the slop their's has. This is the front shaft I am talking about. Hopefully that makes sense. I cannot really measure this, but with them side by side, it is noticeable. There is not any difference in up/down movement between the 2.
I am about to the point to take it to a shop, however I have a feeling they will just throw parts at it, which I can do for cheaper!
TLDR - Bravada vibration ever since I have owned the vehicle, threw all kinds of parts at it, and no change... possible transfer case?
Thanks Guys.
Old 06-15-2013, 02:32 AM
ohsofly's Avatar
I suppose its possible yes. Get a junkyard one instead of taking it to a shop. Shouldnt take too long to swap them out and see what happens. Better than paying a shop to do it for you for sure
Old 08-22-2013, 03:42 PM
KENTUCKYMEL's Avatar
KENTUCKYMEL is on a distinguished road
i have a '98 bravada, and have had problems with vibrations since iv'e owned it. the transfer case knocks like a piston rod, but it hasn't broke yet, although the 4-wd shift motor swelled out like frozen pop can and no more 4-wd now. i have to say it worked like a charm up until that point. another thing is i understand the '98 is a one year only deal, so finding a transfer case is not easy. im going to the regular blazer, at least they are plentiful. the only difference in the bravada and blazer is cosmetic anyway.
broke blazer
04-05-2010 08:00 PM
1baddblazer
10-08-2009 06:11 PM
vegasmason
04-27-2008 04:24 PM
AlaskanGrizz
03-31-2008 06:27 AM
bellert
09-21-2007 08:38 AM
Quick Reply: Bravada driveline vibration 40-60mph and 70+
