Bypassing transfer case vacuum switch - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 06-06-2011, 07:14 PM
ComputerNerdBD's Avatar
ComputerNerdBD is on a distinguished road
Default Bypassing transfer case vacuum switch
Hey everyone. I had a Posi-Lok system installed in January for the front axle. How do I disable the vacuum switch on the transfer case so that I don't have any problems caused by it?
Old 06-06-2011, 07:22 PM
01vortec is an unknown quantity at this point
the posi lock is only to lock in the front diff, you still need to lock in the transfer case so that you have 4wd. only way to disable it is to remove the electronics and convert it to a manual transfer case with a lever or a shifter
Old 06-06-2011, 07:28 PM
Quote:
I realize the electronics are there to stay unless I want to convert it to a manual transfer case (not going to happen anytime soon). I mean the vacuum part only, so the transfer case is electronic and the front axle is cable operated. All I want to do is get rid of the now-unused vacuum parts before they start to leak and cause a problem.
Old 06-07-2011, 09:43 AM
if you mean the vacuum canister under the battery, you could just disconnect them. and plug the hole with a bolt and a ziptie.
Even if it does leak, the transfer case will switch normally. It has nothing to do with the vacuum system to lock in the front diff.
Sorry, i misunderstood your original question.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Vacuum Hoses and Transfer Case Vacuum Switch cjb2145 2nd Gen S-series (1995-2005) Tech 9 07-08-2014 07:02 PM
2000 blazer No Transfer Case Vacuum Switch? paulp64131 Steering, Suspension & Drivetrain 4 12-26-2011 03:52 AM
Transfer case vacuum switch slowhand Steering, Suspension & Drivetrain 4 01-05-2010 05:14 AM
Transfer case Vacuum switch SockJock 2nd Gen S-series (1995-2005) Tech 4 03-04-2009 11:55 AM
replacing vacuum switch on transfer case fred96 2nd Gen S-series (1995-2005) Tech 12 06-08-2007 11:23 AM
Tags
1998, 1998gmctransfer, axle, bad, blazer, bypass, case, caseremove, chevy, front, gmc, jimmy, switch, symptoms, transfer, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
