couple questions here, need help
Old 09-20-2009, 05:53 PM
tattooed.diva's Avatar
tattooed.diva is on a distinguished road
Unhappy couple questions here, need help
ok here is the deal.
i just changed tir rod ends, drive shaft in driver side, shocks(front) now i need to change passanger side drive shaft too, no biggie. i realized last night while driving there is a grinding noise/ feeling in the front. what could this be? also, when driving up the hill it kinda makes a clicking noise and then its gone.... im a chick, know some stuff, but right now im totally lost!
need some good advice, thanks so much in advance
Old 09-20-2009, 09:20 PM
oisinirish's Avatar
Can you "feel" the grinding noise? Does it happen all the time? In 4wd and 2wd? Louder/ more noticeable with speed? Could be a wheel bearing.
The clicking noise. Sounds like it comes from under the truck not necessarily the front? Sounds like a bad u-joint.
Old 09-20-2009, 09:32 PM
it does it in 2wd, and i can feel it too... i thought about bad u-joints, but wanted some opinions/ advice on here!
the clicking comes more from the back, when i slow down, turn and drive up the hill. thats probably a u joint as well?
Old 09-20-2009, 09:38 PM
oisinirish's Avatar
Sounds like it to me. Sometimes when they are going bad you can crawl under there after you've been driving and feel the yokes for the joints and they'll be warm/hot, but not always. If it turns out to be u-joints do 'em both while you have the drive shaft off it'll save the "practice" of doing it again if you just do one at a time..lol.
Make sure to mark all components so everything goes back together exactly the same way as they came apart.
Old 09-20-2009, 09:42 PM
Thumbs up
ill probably replace all of them at the same time. so thanks so much for your advice
Kwillia
11-20-2010 07:11 PM
ZeR2
04-15-2008 07:48 PM
Joey P.
11-30-2006 12:33 PM
jpap
10-25-2006 01:22 AM
Benado
10-23-2006 12:16 PM
Quick Reply: couple questions here, need help
