Clunking noise
Clunking noise
Hi guys I have a 2001 Chevy blazer 4x4 there's a clunking noise at low speeds accelerating and decelerating and turning right I know it's coming from the front drive shaft for sure it's either from the transfer case or from the cv joint on the shaft connecting to the transfer case but not for sure if that's the problem not wanting to spend 200$ on the part and have it still be coming from the case or the yoke so any tips or information is appreciated thank you for the help in advance
Check your upper control arm mounting bolts/nuts. I had a sound that happened under very similar circumstances and my left rear-most upper control arm mounting nut was hand tight :/ Had just had an alignment done too...
Blazin 4x4
10-23-2005 06:11 AM
kwsrv@libcom.com
09-07-2005 05:01 AM
