drivetrain roaring noise - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 06-01-2009, 09:53 AM
a4.34me is an unknown quantity at this point
Default drivetrain roaring noise
My daughter has a 94 S10 4.3w AT 4WD ,after driving 5-6 miles at highway speed starts a roaring noise in drivetrain sounds like 4WD is engaged noise goes away if I slow down and is not as bad if driving up hill or under a load .It has electronic shifted 4WD .
thanks
Old 06-04-2009, 12:08 PM
jstutzman is on a distinguished road
If you even figure this out, please post your findings. My suburban is doing something very similar. I cannot figure out what it is. Mine is like a low pitched howling kinda. if im crusing like interstae driving it drives me nuts. Around town or up hills ect, i dont even hear it. I have had some possible causes being bad U joints, Worn diffs, Worn trannys, Wheel bearings, even back wheel bearings, and CV joints. Darned if i can figure out what it is.
Old 06-05-2009, 02:23 PM
Mine sounds like a truck with "Monster" size tires roaring and it comes and goes with different speed/road conditions .I've had a busy week ,haven't had a chance to even drive the thing but I plan on getting under it in a couple days and see what I can come up with .Thanks for the interest .
Old 06-05-2009, 06:53 PM
cr8390 is an unknown quantity at this point
granted u have a 94 but my 99 did this and it was a bad hub bearing just letting u no
Old 07-05-2009, 11:20 AM
Finally got around to working on the thing again ,figured out it makes the noise when coasting/decelerating so I thought maybe an engine vacuum is having an effect on 4WD vacuum controls .I disconnect the vacuum to front axle servo and it hasn't made the noise since ,I guess the increase in engine vacuum when coasting or decelerating was trying to engage front axle somehow now I just gotta figure if it's the transfer case switch or the servo .I hope this helps someone else .
Old 07-05-2009, 05:22 PM
Sounds like a faulty transfer case switch. Glad you got it figured out!
Closed Thread
Thread Thread Starter Forum Replies Last Post
Drivetrain Roaring Under Acceleration FLBlazerDad Steering, Suspension & Drivetrain 3 08-04-2010 09:25 AM
Grinding/Roaring noise up front.... mtsumedi Steering, Suspension & Drivetrain 2 10-14-2009 01:49 PM
Loud Roaring Noise Sometimes from Engine cr8390 2nd Gen S-series (1995-2005) Tech 10 09-09-2009 07:04 PM
Roaring noise? 68Datsun510 2nd Gen S-series (1995-2005) Tech 9 05-10-2009 09:21 PM
roaring noise on acceleration esemposki 2nd Gen S-series (1995-2005) Tech 3 09-29-2007 04:22 PM
Tags
2008, blazer, case, chevy, drive, engages, front, motor, noise, roar, roaring, sound, sounds, suburban, surburban, tire, transfer, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
