95 Lift
95 Lift
Hello,
I bought a 95 4x4 cpi blazer this summer and its needed tires since, well now comming time to change the tires before winter i really want to lift it and put some bigger tires on it... but as cheap as possible... hopefully you can help me out with suggestions Thanks
Brad
Brad
RE: 95 Lift
how high? as cheap as possible would be to crank up the torsion bars to lift the front about 2" and buy (or make) some lift shackles to lift the rear about 2" all for less than $100... with that and the stock wheels, you should be able to squeeze on some 31's
you could also do a body lift instead (about $200-250) which would be easier on your truck... adjusting the torsion bars will cause wear on just about everything while a body lift will retain the stock suspension settings
or you could do both tbar/shackle lift and body lift. RCars2 has done both and his truck looks AWESOME with 33's
or 6" superlift, tbar/shackle andthe body lift. but you'd be looking at about $2k just for the lift and then you would still have to trim your fenders shell out the dough for 34"-36" tires and new wheels
HERE is some more info
RE: 95 Lift
Thanks for repsonding.
what about leaf springs would that be another cheap way.. by doing the springs, and the shocks obviously what else would i have to do.
I want to do atleast 30" tires. any good places you know of where i can get a good price on a set of tires and wheels?
Thanks
Brad
Thanks
Brad
RE: 95 Lift
30x9.5 tires will fit without any mods...
RE: 95 Lift
Indeed.Or you can always do what I did with my 4dr LT 95.Lifted the T-bars 2" and added some Gabriels High jackers(air shocks).Toque @ 54Lbs.I added 2 small pics...
[IMG]local://upfiles/7104/B017D7A4E97F413985D1C762F617BD16.jpg[/IMG]
[IMG]local://upfiles/7104/C20EABEC96264CE48C51E492E476CCB2.jpg[/IMG]
RE: 95 Lift
Sorry about the double! My mistake
