Front End Looseness, Wobble and Vibration - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 03-10-2010, 10:14 AM
218persuader is on a distinguished road
Default Front End Looseness, Wobble and Vibration
I have a 2000 4 dr Blazer with 150K and in the past 6 months I have been trying to get caught up on some maintenance that had been neglected. I have put new tires, shocks, brakes, u-joints, 3 out 4 ball joints need replaced and both wheel bearings have been replaced in the past couple years. During this time I felt an improvement in the drive increase greatly and now a couple months has gone by and I have developed or feel a “wobble” in the front end. At slow speeds in slightly rough driving the front feels loose and feels like something is wobbling. On the highway I can go 20 miles in one direction smoothly and turn and go back and I get a bad vibration intermittently for a couple miles at a time. I have been back through things looking for something loose with no success. Any Ideas?
Old 03-10-2010, 10:17 AM
Sounds like something in your steering linkage is a bit messed up. As the tie rod ends, pitman, and idler arms wear, they can cause weird things to happen. Especially the idler arm.
Old 03-10-2010, 12:25 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
im having the same issue. the pitman arm and tie rod ends are shot on mine.
Old 03-10-2010, 12:46 PM
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
Try getting an alignment. This happened when I went with bigger tires on my truck I would go past 75 and the thing would be all over the place.
Old 03-16-2010, 01:15 PM
Thanks guys for the ideas, I knew my front rotors were needing replaced. I have replaced them and at that time I just double checked everything and found that the left front shock upper mount wasn’t as tight as it could have been. I tightened everything (I guess my impact gun doesn’t have the torque I thought it did) and I believe this took the wobble out of the front end. The new rotors definitely helped with the vibration in the front, but I still have a intermediate aggressive vibration throughout the blazer. I appreciate the steering ideas, but I assume this would be present at all times (just asking)? I can be driving along cruise set at 65 and I don’t know if a bump, steering wheel move or what will set it off, but this fairly violent vibration throughout the blazer will take off. I can feel it in the seat, the dash shakes and stuff in the back rattles. Then once again I will hit a bump, make my way around a sweeping turn in the road and it will come out of it and drive nice until next time. I drive about 35 miles on way to work and this will happen 2-3 time each way and I don’t believe it is in the same spots. Thanks again for the help and I do appreciate all additional help.
Old 03-16-2010, 01:31 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
unbalanced tires?
Old 03-16-2010, 02:19 PM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
Check your upper a frame bushings to. Sometimes if there really bad you tend to go with bumps in the road. Happened to me and once I changed them it was a more stable ride. Unbalanced tires could be a very good factor too
Old 03-24-2010, 02:13 AM
rsturge's Avatar
rsturge is an unknown quantity at this point
i had a bad vibration when i hit about 60km hr and it would go away in 30 to 40 sec turned out to be a sticking rear calliper. pretty easy fix.
Old 03-24-2010, 01:04 PM
Thanks guys, ended up having a rear brake pad stick and tore up the rotor. I replaced pads and rotors, now she rides alot better. Still have a slight vibration occasionaly and now a strange hum inside, still chasing.
Closed Thread
Thread Thread Starter Forum Replies Last Post
shaking, vibration,wobble tvitale Steering, Suspension & Drivetrain 23 07-04-2013 08:35 PM
vibration/wobble spidey1 Steering, Suspension & Drivetrain 4 09-16-2012 08:38 PM
wobble wobble ericthughes Full Size K5 Tech 4 10-09-2011 09:40 PM
Looseness in lower column DaveHearne Steering, Suspension & Drivetrain 0 02-26-2011 05:34 AM
Front End/Steering - Wobble, Shimmy, Vibration - All speeds ZR2Driver 2nd Gen S-series (1995-2005) Tech 7 01-21-2010 04:08 PM
Tags
aligment, blazer, chevy, driver, drives, end, front, makes, silverado, tire, tires, truck, wheel, wobble, wobbling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
