Front End/Rear End
Front End/Rear End
I know someone has probably asked the question before but I could not find the response. Here is the rundown:
I just bought an 87 K5 as a project truck for my daughter and I to work on. The front and rear end are geared differently. I would like to do swap out one or the other, what resources can I use to reference the repair? Is there generally a preference to which I would switch? The truck will be for her upon completion and may do some light off road work but nothing too crazy (South Texas is flat as a pancake).
It is our first build, but I have a decent amount of tools, patience and time...not to mention I am mechanically inclined.
Thanks in advance!
Thanks in advance!
Id do the rear before the front if it was me. For now you need to find out what gear ratio either one is.
google " gear ratio counting teeth" and read into how to figure it out.
There should be a sticker in the glove box,or somewhere. it has a bunch of 3 letter/digit codes on it. find any of em that has the first letter g. itll be like gu1,gu2,gu3 etc. post back. Problem is its hard to tell which of the 2 diffs has been swapped unless you can tell by worn nuts,bolts,and gouges. etc
trukker
06-13-2011 07:03 AM
brino1
02-25-2011 08:05 PM
ligero18
11-04-2009 12:38 PM
ComputerNerdBD
03-18-2009 06:13 PM
