Gear Oil - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 08-27-2009, 02:25 PM
danmiranda is an unknown quantity at this point
Default Gear Oil
So I went to the GM Dealer today, and in the parts department they told me "You need about 2 Lt. of Autotrack II Fluid for the Front Differential. So I finished servicing it, and put it back together. This seems weird, I put it in, and it drives fine. I know the T-Case uses it, but I just want to be sure that i'm not making a big mistake.
Old 08-27-2009, 02:40 PM
NVANZEE's Avatar
we use 80w 90 at the dealer i work at. not sure what the weight of the autotrack is though
Old 08-27-2009, 02:46 PM
Yea, It seems really weird to me. I mean it drives fine, probably better than it did with the old oil and mud in it from after I sank it (part of the reason I serviced it) Its not hard to change, I may change it if need be. I plan on servicing the rear axle and that takes 75w90, I believe.
Old 08-27-2009, 04:12 PM
nj4x4blaze's Avatar
That's odd they said to use that for the front diff. I know I put 80w-90 for my front diff and rear diff. I still need to drain out my transfer case and add new fluid but I've been too busy to do that.
Old 08-27-2009, 06:14 PM
NVANZEE's Avatar
Quote:
There shouldnt be mud in it. the only way mud and water can get in is through the ven tube which i believe goes up to the left of the radiator. If you go through really deep stuff i would recomend extending the tube.
Also 80w90 goes in the front and the rear
Old 08-28-2009, 09:30 AM
Never heard of it being used in a differential... 75w90 synthetic gear lube is what I used in the front and rear diffs on my old 2000 Bravada. There is nothing up front which would need the AutoTrak II fluid...
My FSM's and online tools all call for either GL-5 80w90 or Synthetic 75w90 gear lube for front and rear axles.
Old 06-05-2010, 12:03 PM
GunsOfNavarone is on a distinguished road
Old post but thought I'd chime in. I accidentally put AutoTrac II in my front differential and it ran great. When I discovered my mistake, I converted back to GM gear oil. Didn't run as well but I need the Bravada to last so I am running factory specs. Ran it about 500 miles with the wrong fluid (1999 Bravada)
Closed Thread
Thread Thread Starter Forum Replies Last Post
goin for 35s...3:73 gear shud i re gear?? 8five-k5 Full Size K5 Tech 2 11-10-2010 02:00 PM
What gear oil to use on differential? ExplicitYourSelf Steering, Suspension & Drivetrain 9 06-16-2009 10:26 PM
Gear oil in motor bodean Engine & Transmission 4 02-18-2009 03:55 PM
Oil... Oil... Oil... todaresqSL2 Engine & Transmission 5 11-10-2008 02:47 PM
gear oil in carpet Philly Assassin Detailing 21 02-22-2008 09:02 PM
Tags
1996, 1999, 2000, axle, blazer, bravada, chevy, code, differential, end, fluid, front, gear, location, oil, put, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
