rear diff/drive shaft issue
Old 09-20-2010, 04:08 PM
VonBerry's Avatar
VonBerry is on a distinguished road
Exclamation rear diff/drive shaft issue
alright well within the last 2-ish months i have been hearing a whomping noise coming from my rear end as i drove and the sound would always get louder and faster the faster i drove. and it started to worry me a couple days ago when it got ridicuously louder. i got the rear end off the ground and let it idle in drive and listened, my rotors are fine as well as the tires and brakes. i looked underneath and saw some fresh oil around the differential where the drive shaft meets the rear diff. and the whomping noise is coming from the drive shaft i found out. and i know that the seal is broken and i think the bearing may be shot too. but thats what i think, if anyone has any clue whats wrong please let me know
Old 09-21-2010, 02:00 PM
77Nova's Avatar
77Nova is on a distinguished road
I'm having the same issue right now in my 89. When I had my 87 K-5 it happened too and when it went, it went in a glorious fashion, I'm just lucky I wasn't going fast. I actually had to hold the gas while trying to stop to keep the pinion angle right at the end. I wound up replacing the whole rear for 35 bucks because the dude wanted the thing out of his yard. I'm pretty sure mines a bad bearing as well. Not looking forward to it but gonna try doing it without removing the rear from the truck so I don't have to replace the U-bolts and all that stuff.
Old 10-13-2010, 09:24 PM
Chavez324's Avatar
Chavez324 is on a distinguished road
Same thing here, 97 blazer @ 189,000mi. Got it checked at Midas today & they gave me a $1,400 estimate for the pinion bearings to be replaced. I plan on just finding a another rear end at a junk yard.
Old 10-15-2010, 11:52 AM
VonBerry's Avatar
well i found out what the noise was it was a wheel bearing but i do need to replace the pinion seal to stop some leaking, and may be the pinion bearings cause theres a whine i start to hear at about 35mph
Blade_24k
02-26-2014 03:03 PM
danyboy
12-11-2010 11:16 AM
street101
10-29-2010 04:17 AM
lizzj70
06-23-2010 06:57 PM
dlihcsnatas
12-28-2008 07:54 PM
Quick Reply: rear diff/drive shaft issue
