Grinding noise from front end while driving!
garynye30 -
I am glad it worked out for you. Did you notice at all if the bearings had come loose? On mine that was the case. At first I thought the bearings were worn and would need replacement but when I disassembled everything and inspected them they looked fine? So I just greased them up and reassembled everything making sure to tighten the nuts properly. After that the problem and the noise went away.
I took a look at the bearings. Could see nothing wrong with them. So I did not even mess with them. The hub was making a grinding noise when I turned it by hand. The only other item I found that looked bad was my upper ball joint on the driverside. Other then that it seems to be fine now.
Bolbol
02-02-2015 02:55 PM
bowshooter1
03-10-2012 06:31 PM
chad911
02-02-2012 07:41 AM
JZRALNC
04-14-2008 11:16 PM
