how do you adjust transfer case shift linkage - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 12-17-2010, 02:30 PM
jacobbuniger is on a distinguished road
Default how do you adjust transfer case shift linkage
My 1987 k5 slips quietly out of 4 hi and 4 lo so I assume its the shift linkage I've read my manual but still scratching head over the instructions. Any and all help, tips, and tricks would be helpful
Old 12-17-2010, 03:12 PM
What do you have for a transfer case? It should be the NP208, but you never know with older vehicles.
Old 12-17-2010, 03:26 PM
Oh yah sorry it is just the same ol np 208
Old 12-17-2010, 04:08 PM
On the NP208 linkage, there is a threaded portion of the linkage that has a nut on either side of a post type fitting that will attach to the linkage. Basically, you make sure that the adjustment is such that there is no binding between the shifter in the floor and the arm on the transfer case. I do this by disconnecting the shift linkage at the transfer case and adjusting the linkage so that it slips nicely into the hole on the arm on the transfer case. It should do this in all positions.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Will a transmission np236(4 button) transfer case fit np233 (3 button) transfer case Flyfishen Engine & Transmission 3 01-24-2014 08:27 PM
How do you adjust the idle on a throttle body? Bigguns72 Full Size K5 Tech 8 10-29-2010 07:52 PM
4.3 high idle how do you adjust it? midnightryder 1st Gen S-series (1983-1994) Tech 2 12-29-2009 03:43 PM
Got no Park. How do you adjust the gear selector cable??? er.rigney 2nd Gen S-series (1995-2005) Tech 1 06-03-2009 10:16 PM
Shift Linkage adjust help Bonovox Engine & Transmission 2 09-05-2007 07:25 PM
Tags
1974, adjust, adjusting, adjustment, blazer, case, chevy, lingage, linkage, lowering, np208, problems, shift, shifter, transfer, transfercase
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
