Power steering confusion
So I just got done replacing pitman arm, idler arm, and 2 ball joints on my 2003 blazer 4wd, and now my power steering doesn't work. It worked fine before and I connected everything properly, added power steering fluid as needed there are no noticible leaks I'm stumped. Thank you
Did you put the serp belt back on? Did you raise the front wheels off the ground and cycle the steering wheel lock to lock countless times to bleed air out of the system? I don't think the lines can be crossed but I don't remember for sure so it's probably a good idea to check that as well.
