Wheel bearing/hub removal
So...I'm trying to replace the drivers side wheel bearing/hub assembly on my 98 4WD Blazer.
I have the vehicle up, caliper off, axle nut off, three bolts to the back of the hub assembly off...and it won't budge.
I've tried a puller on the axle and pushes the axle back and doesn't pull the hub off.
I'm frustrated and stuck...what am I missing?
Any and all help is appreciated.
try swinging a good sized hammer to push out axle....most likely rusted on there good and tight...mine came off with some p.b. blaster and hammering.....just dont swing to kill and damage anything
Got it...like Warthog said, just needed a bigger hammer.
Thanks again.
Thanks again.
samurai_24
10-02-2009 12:39 PM
bigrackhunter50
04-11-2007 01:08 AM
