S10 Blazer 4x4 Issues
I have a 2002 S10 Blazer with an on going issue with the four wheel drive. The vacuum actuator under the battery keeps tearing. I've replaced it several times. Does anyone know of a recall on this item? Are there any alternatives out there for a more reliable 4x4 system. Any help would be appreciated.
If I'm not mistaken you can use a cable from the cab to lock the front diff instead of the vacuum set up..... its called a posi-lok cable.....I have seem them on ebay for a ton of different trucks. Search Blazer posi-lok cable and you will see it.
They do make them. Some people have trouble installing them due to the length involved from the cab to the front differential. All the bends in the cable causes it to be difficult to engage/disengage the front axle. They then decide it is not worth it and repair their problem and just go back to the original setup or they do the bravada swap..
On the 2nd generation they are under the battery tray. I have seen the battery leak acid and destroy the baffle on the actuator.
Some people have had good luck replacing the entire vacuum system with the Posi Lock cable, but also have seen people go back to the original vacuum system or even the Bravada axle swap because they had too many bends in the cable and it was too hard to engage and disengage.
the Bravada swap is good, it gets rid of alot of stuff but the downside is, is that the axle is always turning, even not in 4wd. Don't know how much it costs in the increased fuel costs of that.
Dallas1970
02-22-2019 05:05 PM
DKlos
08-22-2011 05:17 PM
RickBlazer
06-23-2011 04:59 AM
BaLListic_Evo
06-04-2010 03:38 PM
