Steering box replacement - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 05-02-2011, 01:26 PM
ComputerNerdBD's Avatar
ComputerNerdBD is on a distinguished road
Default Steering box replacement
Hey everyone. How difficult is it to replace a steering box on a 98 4x4 Jimmy? What should I expect when I speak to a mechanic? I can get the part from Advance, but I cannot replace it myself. Is it a $1000 job to swap it out? The reason why I need to have it replaced is because there is like 2-3" of play in the steering wheel and it is NOT in the front end or the rag joint and I can't drive this truck a long distance like this. In fact, the steering shaft was already disconnected a few months ago and they found play in the box, confirming it.
Old 05-02-2011, 04:01 PM
wild bill is on a distinguished road
I replaced mine myself. The worst part was getting the pitman arm off the centerlink. Took my b-in-law beating on it with a pickle fork and hammer while I was using an air hammer from the bottom.
Old 05-02-2011, 05:56 PM
abig84's Avatar
spray down the lines where they attach to the box soon as you can so they can soak. that was always the biggest problem i ran into was lines braking due to rust. and that pitman arm is a pain. if you have access to a impact, just leave the pitman arm on that gear box and do it on the vise outside the truck
Old 05-02-2011, 07:39 PM
Little Roober's Avatar
Little Roober is on a distinguished road
The hardest part for me was disconnecting and connecting the power steering lines to it. (96 Jimmy) For the pitman arm, just use a two jaw puller and a vise. Should only take seconds.
Old 05-02-2011, 09:20 PM
NVANZEE's Avatar
yeah i have done one before and it wasnt too bad to do. if you havent replaced the pitman arm I would just recommend doing that at the same time. Thats what i did and it made it much easier. That way you dont have to fight the old one off.
Old 05-08-2011, 10:46 PM
Ok Thanks for all the tips. I got the box today at Advance. It is a remanufactuered Fenco unit. Is that good? Didn't want to have to deal with 2 way shipping with these gas prices (also with the core). Now I just have to make an appointment to have it replaced locally. The shop I go to is very good and doesn't try to sell me unneeded stuff, so I think they will try to reuse the old pitman arm by default. The old lines look good for over a dozen NY winters, so I don't think they will have problems removing them (I had rusted brake lines in that area that were replaced in September and they didn't have trouble removing them). However, I will spray them before I go to the appointment.
Old 05-17-2011, 05:20 PM
Got the box replaced today. They also replaced the pitman arm because they said there was play in that and 2 ball joints. The steering is tight now with very minimal play (I can't feel any). With the ball joints, I don't know how that is possible because all of them are between 1 and 2.5 years old. But sure enough, there was a bit of play on the right front wheel. It is like a hair, but it is noticeable when I jack it up from the control arm (but I can't feel any when I jack it up from the frame). How is all this possible? Would adding grease at the next oil change help? I always grease them at every oil change.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Heavy steering with new steering box ctyler Steering, Suspension & Drivetrain 6 01-04-2013 01:37 PM
steering box replacement cocaptain Steering, Suspension & Drivetrain 2 03-17-2011 08:22 PM
Steering loose. Adjusted gear box and checked linkages. Box need replacing? AKCoastie 2nd Gen S-series (1995-2005) Tech 13 11-01-2010 03:41 AM
Steering Gear Box Replace/Steering Wheel Misaligned caseroj Steering, Suspension & Drivetrain 7 10-20-2010 08:10 AM
My Blazer box (tool box) 88s10Blazer General Chat 1 06-15-2010 10:10 PM
Tags
30, 5w, 98, 99, blazer, bo, box, change, chevy, gmc, hard, jimmy, replace, replacement, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
