TORQUE specs on steering bAR Balljoints on AN 89 BLazer
I'm replACING THE FRONT END ON an 89 BLazer. HAD TO CHange out the steering bAR THat goes from wheel to wheel. WANTING TO KNOW WHat the torque specs ARE FOR THE BAll joints AT Each end? aND Maybe the toe in?
RE: TORQUE specs on steering bAR Balljoints on AN 89 BLazer
You'll need an alignment after a tierod end change. That is what you are talking about right, the tie rod ends?
Anyway, the the torque on the castle nut should be 40ftlbs, then tighten to the next closest opening for installation of the cotter pin.
And what's with the spastic caps lock?... Very annoying.
SyberTiger
07-03-2014 01:09 PM
dougs10
12-14-2010 03:24 PM
