Transfer case vacuum switch
I have the common 'flashing buttons but no 4wd' problem on my '99 Blazer here in the UK. Everything else seems OK so I want to replace the transfer case vacuum switch. Trouble is I can't even feel it never mind see it or get a spanner on it. Anyone got any hints on how to change this part??
Thanks.
Thanks.
3-button or 4-button dash switch?
Hi,
4 button. Auto, 2hi, 4hi, 2lo.
Thanks.
Thanks.
You are in luck. The reason you cannot locate the transfer case vacuum switch is because the NV236 (4-button switch) does not use one. Instead, it has an electronic vacuum solenoid on the firewall near the distributor.
That explains a lot! Thanks for the advice; brilliant.
cjb2145
18
10-06-2018 04:46 PM
paulp64131
12-26-2011 03:52 AM
fred96
06-08-2007 11:23 AM
