Zr2 vs. Non zr2
#31
However, you still don't have to remove the steering shaft. When it was stock height, I used a combination of two universal extensions. You have to take your time, but it works, and is a helluva lot easier than removing the steering column.
Last edited by Psychropod; 12-04-2009 at 11:09 AM. Reason: Added the tip at the end.
#32
Sorry if this is off topic, but I'm thinking about getting a Blazer, and deciding on model. Does the ZR2 have a limited slip or locking rear diff? And is it practical to clear 33's on a ZR2? I see Logan is running 33s. I want an everyday driver than I can setup to pull the quads out to the trails, and ride the trails out to the weekend bonfires. Just wondering if a ZR2 would be a better platform to start with than a regular Blazer.
#33
The ZR2 will roll off the line stock with 31x10.5's so right there you have jumped past regular blazers with anything short of (on average) +2" up front, +2" in the rear AND a 2" body lift. ZR2, while not made to be king of the trails, is leaps and bounds ahead of stock, and highly capable. as for the rear end, G80 Gov-lock. you will find a few articles and posts running through the pros and cons of this style axle. It is a "locking differential" but is not a 'locker'. it's a bit confusing, but better than nothing, and better than limited slip. Read it up. you'll see.
#34
#35
Ill I needed on my ZR2 was the 2" torsion bar crank, and add a leaf in the rear to clear 33's.
And im picking my new axles up next sunday. Dana 44's from a 1980 Wagoneer. Then ill rebuild them over the next few months. Im putting an air locker in the front, and a lock rite in the rear with 4.10:1 gears.
#36
although, i am about to stick a set of zr2 torsion bars in to stiffen up the front a bit.
a zr2 was my dream, but i had to settle for a 4dr wanna be z.
#37
thats why i said (on average) then listed the mods
Spectreblazer
02-13-2010 04:59 PM
