ZR2 center steering link on a 4 Door? (With stabilizer/damper mount)
did you ever install this? how did it work out. I have debated repeatedly changing the center link so that i can add the stabilizer. I feel like it will at the very least prolong the life of the steering box. At some point i need to change my steering box since i still have some slop and all new steering components otherwise and no play in the rag joint. if thats the case i might as well change the center link at the same time.
The ZR2 center link is NOT compatible with the non-ZR2 s-series trucks. It is 4" longer than the non-ZR2 center link (see quote below). If you want one with the 5th hole for the steering stabilizer use a center link from a 1st generation S-series Blazer or truck. A stabilizer with the same dimensions as the one from the 1st generation Blazer will work perfectly for your 2nd generation truck.
Well I am going to go ahead and confirm this myself. Went to pull the center link today. Before removing it I measured both my current center link and the ZR2 center link.
2ND gen LT/LS 4WD center link = 27" long from end to end. Pitman arm - idler arm holes = 17.5"
2ND gen ZR2 center link = 31" long from end to end. Pitman arm - idler arm holes = 17.5"
With all of that being said, the ZR2 link is NOT compatible with the LT/LS blazer. Not without serious modification to the tire rods anyway.
I know that the outer tie rods could be shortened and using a tap & dye set, the threads lengthened to make the ZR2 center link work on a non-ZR2 but when it all boils down to it, that's just not practical and would need to be redone every time the outer tie rods needed replaced.
Now does anyone know for sure what non-zr2 blazers came with the 5 hole center link for the stabilizer shock? I'm still seriously looking for one of these links.
Not sure if the OP ever found a suitable center-link, but as I said previously, I have the 1st gen S10 center-link installed on my 2002 Sonoma. I am using a stabilizer with the same measurements as the 1st gen S10, using the factory hole on the center-link and the factory frame mount on my Sonoma. This is the same center-link that the OP referenced in the screenshots he posted with the same part number. It has exactly the same measurements as the 2nd gen center-link and also includes the 5th hole for the steering stabilizer. In my opinion its a good upgrade, especially if you're already replacing steering components at the same time.
MDE8
12-04-2010 05:45 PM
ChrisAttebery
09-24-2007 07:20 PM
