22's on extreme
RE: 22's on extreme
i was wondering how low you lowered it and if the 22" rims worked email me back at blazin691@hotmail.com
RE: 22's on extreme
ORIGINAL: Lotus
Thanks everybody, i am gonna try the 22's i think, if they dont work, ill put em up for sell!
That's a lot of money to be throwin' at wheels that may cause problems when they are turned. The problem if the wheels/tires don't fit, you won't get everything out of them that you put in. I can't help but think of what the ride quality would be like. Hope ya don't have hemorrhoids.
RE: 22's on extreme
youll b fine with the 22's, if you havent figured it out yet, yes the front will rub when u cut the wheels all the way to the right or left. Even though i have air ride on mine, when the truck is all the way up which is at stock height, i have no problems with the 22's
RE: 22's on extreme
Hi , I joined today to get some info from those who know about wheels. I have a 2001 Xtreme Blazer that I use for my work truck and want to get some new wheels. I have 20"s on my SS TrailBlazer and they look too large for the X . Should I do 18"s or are 20"s the way to go? And how about tire size? Thanks
RE: 22's on extreme
20's are the way to go texastechdad, I have 18's on mine for the moment and don't have any problems!! I have put 20's on other blazer's and they are perfect with the right size tire. Now if your looking to ride at stock height and put wheels on then 20's will be perfect!! Tire size for a stock height blazer on 20's will be depending on width of the rim 245/ 35r20. Now if room permits then you might be able to go with a 40 series to give you a little more meat around the rim!!
22's
I have 22's on my Blazer - Rubs a bit when doing "tight" turns but that's it.... I'm going to lower mine as well - look at some pics in my album and you'll see the room I have in the well - People have done it....
My rims are 22x9.5's and they fit and ride....
i have 20's on my xtreme with stock suspension and they rub the frame when turning.
in all honesty, even though big rims are cool, i much prefer the look of a nice 17 or 18 tucked up in a wheel well
dubluj
12-12-2005 02:09 PM
