235/70R/15 For 1998 4x4 4dr Blazer?
Old 01-19-2013, 07:08 PM
teamrojas's Avatar
teamrojas is on a distinguished road
Default 235/70R/15 For 1998 4x4 4dr Blazer?
Will 235/70R/15 fit on my 1998 4x4 4dr Blazer?
Old 01-19-2013, 07:35 PM
matt9589's Avatar
matt9589 is on a distinguished road
i just got new tires today for my 98 4 door.. I got 30x9.5 R15. I think 235/70/R15 is the factory recommended size
Old 01-19-2013, 07:51 PM
Twip's Avatar
i have 235/75r/15 on my 2wd and my 4x4. both 1998 4doors. so you should be able to fit those without any trouble. on my 2wd, they rub just a little bit in tight turns. on my 4x4, they dont rub at all...although the tread has worn down quite a bit. i dont know how much difference there is between 70 and 75 as far as height but it cant be all that much.
Old 01-20-2013, 06:40 AM
Rumblur's Avatar
Rumblur is on a distinguished road
your gas mileage will go down with the 75's over the 70's if you do a lot of stop-n-go or have many hills around there.
Old 02-04-2013, 12:25 PM
USMC3782's Avatar
USMC3782 is on a distinguished road
it is five percent shorter tire. That's what the numbers mean.....
Old 02-04-2013, 05:12 PM
Rumblur's Avatar
yes, the 70 = 70% of the tread width. So the sidewall of the tire is 70% of 235mm, versus 75%. Shorter tire = more leverage = less effort on the engine to do the same work = better MPG (usually, there is a point where you'll be going the other way).
Old 02-04-2013, 06:25 PM
JAKT's Avatar
JAKT is on a distinguished road
I have a cheap set of Uniroyal Laredos (235/70/15) that I use in the summer and a nice set of Firestone Winterforce (235/75/15) studded tires on my Jimmy at the moment (which by the way are awesome in the snow!). I am searching for a good set of 30/9.5/15 AT tires for the summer; BF Goodrich has some decent ones but General Grabber AT2's are the best deal for your dollar. 30" tires are the largest tires you can put on a 2nd generation stock S-series without trimming your fenders or a lift kit.
Old 02-04-2013, 06:45 PM
newguy's Avatar
235 75/15s are basicly 29 inch tires
Old 02-04-2013, 06:49 PM
newguy's Avatar
vinniev
Tires and Wheels
06-09-2010 09:52 AM
ImScrewed92
Tires and Wheels
08-22-2009 07:21 PM
neurotox
Tires and Wheels
04-20-2009 03:44 PM
bodean
Tires and Wheels
10-20-2008 06:25 PM
Quick Reply: 235/70R/15 For 1998 4x4 4dr Blazer?
