235x75X15 VS 31X10.5X15 - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 11-06-2010, 10:31 PM
greatwhite's Avatar
greatwhite is on a distinguished road
Default 235x75X15 VS 31X10.5X15
Hi all
This may be a pretty dumb question, but I could not find anything on the site. I have read everything about cranking the torsion bars and shackles, already done. How much more lift will I get going from 235x75X15 to 31X10.5X15
Old 11-06-2010, 11:17 PM
TripleBlackBlazer's Avatar
Roughly .9 to 1.4 inches.
31x10.5x15 is equivalent to between a 265/75/15 and a 265/80/15 (if it exists). According to miata.net's tire size calculator, those sizes show a sidewall of 7.8 to 8.3 inches. Take that and subtract the stock (235/75/15) sidewall of 6.9 inches and you get .9 to 1.4 inches.
Of course this is all dependent upon the manufacturers actual numbers as some 31" tires aren't true 31" but could be just over 30".
Old 11-06-2010, 11:19 PM
greatwhite's Avatar
So then do I need to put on a suspension lift?
wlorton's Avatar
Quote:
Divided by two? or did you already do that??? (1.05)
Lol.... Not very much, I would be more worried about them actually fitting....
Old 11-06-2010, 11:20 PM
Rottidog's Avatar
Try googling a 'tire calculator' oh heck ... here http://www.1010tires.com/TireSizeCal...bmit&reset=yes
Keep in mind that this is just a general rule of thumb. Hardly any tire that says eg: 31 x 10.50 is actually 31" tall or 10.50" wide at the tread. You may have to go to the manufactures website for specific dimensions.
<edit> & I'll edit my post to say uhhh yeah TBB, I agree?! lol
Old 11-06-2010, 11:22 PM
Edited my original post to explain. Sidewall minus sidewall would only be 1 side since extra sidewall on top of the tire wouldn't contribute to lift.
Quote:
I thought you already did torsion bars and shackles? Or did you just already search it? If you haven't, then read the many threads on the subject already in existence. If you did, then you SHOULD be fine. Rim backspacing and offset will determine if you rub. Every truck is different. Or I should say that every truck's torsion bars are different.
Old 11-06-2010, 11:23 PM
greatwhite's Avatar
My undrestanding is I will need to do some trimming for the tires, no problem with that, I have some experience lifting a Jeep. Just cant spend to much on this (lack of $$$)
I already cranked the torsion bar 1.5 inch (both done the same). I was just hoping to get a little more clearance then approx 1 inch but actually that is what I was expecting.
Thanks
I think I will have to still do some trimming to fit 31's
Last edited by TripleBlackBlazer; 11-06-2010 at 11:33 PM. Reason: Combining consecutive posts. Please use the EDIT function to add to your last post if no one has replied.
Old 11-06-2010, 11:55 PM
mdehoogh's Avatar
Super Moderator
FWIW, converting the metric size to inches, 235/75r15 is 28.87" x 9.25" x 15", compared to 31x10.5x15, that's a 2.13" height difference and 1.25" narrower treadwidth. Since you're wheel is only resting on one sidewall, you halve the height difference for 1.065" total height gain.
That's all based on the premise that a given tire is the exact size they say it is (which is generally untrue)
Old 01-05-2011, 12:36 AM
okiedoak20's Avatar
for the 31x10.50x15's installed on my 2000 Envoy w/stock rims, i have to do the shackle/torsion bar and a P.A. 2" body lift, and some minor trimming on the rear side of the front wheel openings
Closed Thread
Thread Thread Starter Forum Replies Last Post
31x10.5x15 on stock suspension and rims? fletch125 Steering, Suspension & Drivetrain 8 03-28-2014 12:57 AM
Fitting 31x10.5x15 tires heeb2424 Lifting Tech 43 02-08-2012 07:40 PM
31x10.5x15 TrailCutter Radial M/T blazinhigh98 Tires and Wheels 3 09-05-2011 04:35 PM
Nexen Roadian MT 31x10.5x15 has any one tried these RebelJimmy96 Tires and Wheels 0 12-04-2009 06:52 PM
31x10.5x15 fit? krkline2gdsm Tires and Wheels 4 10-29-2007 11:41 PM
Tags
10, 1998, 2357515, 235x75x15, 31, 31x105x15, 4wd, blazer, comapre, convert, lt, price, rear, shackles, tall, tire, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
