3 of the Same, 1 Different
Old 03-24-2009, 02:39 PM
Xander2002's Avatar
Xander2002 is on a distinguished road
Default 3 of the Same, 1 Different
When I bought my 2002 blazer it came with 4 235/70/15 (28x9.3/15) firestone tires, unfortunately about a month and a half ago my back right tire went flat so I out the spare on which is a 235/75/5 (18.9x9.3/5). ive now been driving around for about a month and half to 2 months. im pretty strapped for cash right now so thats my reason for not getting a new tire yet. I just want to no if driving around with a different size tire will cause any damage to any parts?
Old 03-24-2009, 03:20 PM
oisinirish's Avatar
Everything I've heard is that two different sized tires will cause extra wear on your rear differential.
Old 03-24-2009, 07:17 PM
Put the larger tire on the front and do NOT use 4wd. But get a properly sized tire quickly. Some tire shops sell used tires that still have good tread on them. Check around, you may be able to get a decent tire to use for cheap.
Old 03-24-2009, 08:13 PM
WolfPack's Avatar
ebay has good deals on some used tires
Old 03-24-2009, 08:47 PM
mdehoogh's Avatar
Avoid burnouts with different sized tires, or else you'll end up like this dude
But as others have said, make sure you have the same sized wheel/tire on both ends of the same axle, 70's on the rear and 75's on the front and not 70's on right side and 75's on left side
Old 03-24-2009, 10:11 PM
TripleBlackBlazer's Avatar
truth
Old 03-25-2009, 10:20 AM
Xander2002's Avatar
thanks for all the input guys, it really helped
Old 03-25-2009, 01:37 PM
oisinirish's Avatar
Just a question on this subject. Will different size tires on the front affect braking and handling?
Old 03-25-2009, 01:40 PM
It will affect handling, but not really affect braking. It is just a lot safer for the driveline components so long as 4wd is not used.
coolcat0285
11-14-2012 07:35 PM
pdl122000
09-05-2011 04:28 PM
mikepro
08-15-2011 07:03 PM
AmberRose
08-30-2010 08:58 PM
BlazerBrendan
10-12-2008 09:12 PM
Quick Reply: 3 of the Same, 1 Different
