Wheel Tech Help
Wheel Tech Help
So I've got a line on a decently priced set of ZR5 wheels off a crew cab S-10. Haven't looked at them yet, but the seller claims "inner rim on 1 wheel is slightly bent but wheel was checked with roadforce wheel balancer and passed system tests". Says it's on the inside so you can't see it.
Without knowing more, I'm hesitant to even look at them (he's a bit out of my way). There's more to wheels than balance. Worried the bend could cause problems with leaks/seal with the tire. I also don't know anything at all about wheel repair.
Overall, I'm inclined to pass. It is a good deal. Any suggestions on what to be concerned with?
Pick 'em up if they're that good of a deal. Wheel repair can't be prohibitively expensive, especially for a wheel as good looking as the ZR5.
I hit a curb quite a few years ago in a '76 and cracked both rims on the driver's side on aluminum alloy rims. Much to my surprise, they never lost air nor balance. I drove on them for another 3 years until I sold the car.
With that said, if the price on the set is that good and just the one rim ends up being unrepairable you can always find another single rim to replace it.
you'd be amazed what damage to a wheel will still hold air-and deive without any issue.
now to find that pic of my little brother's smashed RX wheel........................
**edit***
ok, i' was only ably to find one shot that (kinda) showed the damage. the wheel/tire was on the car when he bought it, and they passed it through the safety like you see it. he did not do the damage himself.
I'd say do it if it is a good price. I mean worst comes to worst is you can always buy another zr5 rim which would still be cheaper than buying 4 new
Well, I went for it. $200
those look almost perfect except for the minor scratches on the one wheel
Yeah, the picture makes that one look worse than it is. I do have to track down a decent price on two new center caps though.
In any case, they're not getting installed for quite a while. Going to hold off until next spring...that's when I'm doing the 2" body lift and moving up to 31" BFG's. I'll either polish them myself or get them reworked by a real wheel shop.
sounds like a good plan
